Notices
High beam working. Low beam not working 2011 tsx
Old 07-09-2019, 03:01 PM
New Member
Question High beam working. Low beam not working 2011 tsx
Good Afternoon
I have replaced the ballast, wiring harness and headlight bulb on my TSX. The relay switch and fuses have been checked, they work. For whatever reason there is no power getting to my low beam light, Can someone please advise me what else I can do to fix this problem. Thanks so much.
KJEFFERIES68 is offline
Old 07-09-2019, 03:24 PM
Received 5,938 Likes on 4,760 Posts
did you probe the low beam harness to confirm no power? Can you clarify how you checked relays and fuses?
thoiboi is offline
Old 07-10-2019, 09:12 PM
New Member
No. Is there a low beam harness wire or something that can be replaced? If so can you tell me the exact part name I need to get? The fuses and other parts were checked with a voltage detector.
Old 07-11-2019, 04:51 AM
Registered Member
TSXV6Guy's Avatar
I have seen old fuses test OK with an ohmmeter but fail to pass current under load. Suggest to replace the fuse with a know good one, and swap the relay with a know good one. This will absolutely rule out those items, before you start into complex diagnostics (wire harness etc).
TSXV6Guy is offline
Old 07-14-2019, 10:17 AM
New Member
Which fuse should be replaced?
Old 07-14-2019, 12:49 PM
Registered Member
Bad low beam ground or bad light switch.
01acls is offline
isaiahd804
04-27-2019 08:22 PM
Kevin17112
05-13-2017 04:49 PM
Kiljaedoen
First Generation CL Discussion (1997-1999)
21
08-29-2004 01:52 AM
moforose3.0
51
04-13-2003 05:18 PM
Quick Reply: High beam working. Low beam not working 2011 tsx
