Has anyone replaced their cup holder? Lid will not stay closed!
Just bought a '10 TSX, and the cup holder lid will not stay closed. Sometimes it latches briefly, only to pop open seconds later. It looks like the unit is connected to the main center column, so it doesn't appear to be a simple swap.
My car's out of warranty, so the total cost to fix this is close to $300! The part alone is $212. That's insane.
I read ssjoeboe9's awesome trim removal post in the DIY section, but I didn't see anything about taking out the cup holder unit.
Has anyone done this, or do you know where I can find a step-by-step guide on how to do this myself?
I know this is a trivial thing, but the interior looks so sleek with the lid down. Would like to fix this somewhat inexpensively if possible.
TSX AMG Type //M i-VVT
Mine did this. Remove all the trim, take out the center console piece and there is a screw which connects the cupholder assembly to the rest of the center console. loosen the screw, pull the cupholder assembely out a little bit and re-tigten the screw. This probably sounds confusing, but you will see what i mean once you take it apart.
I think I fixed it. Pulled the whole center unit out, and after a lot of poking around, I realized the problem was in the latch - it just wasn't grabbing effectively. Took the whole latch unit apart, cleaned it, reset the spring and the metal insert, and it seems to be working ... for now.
I like saving $300.
I like saving $300.
my cupholder doesn't have a lid
nevermind...yes it does. I always leave it open.
I had a pen stuck in the lid crack of mine and also had problems with the lid staying shut. I didn't have to remove any side trim, just pull straight up on the lid and the inner cup holder "taint" to pull everything out. I disconnected the heated seat switches and pulled the whole assembly out of the car.
Once out, I flipped it upside down and the pen fell out of the crack. I unscrewed the 5 screws that secure the cup holder assembly to the center trim. I removed the inner rubber liner and washed it (4 rubber tabs on the top edge of the assembly and 2 tabs at the bottom of the liner that is hidden by a pad that's stuck to the bottom of the assembly).
I removed the lid from the cup holder assembly by 2 screws at the pivots and cleaned the lock/release mechanism and the tab that goes into the mechanism. Everything works as good as new now.
It probably took me half an hour to remove, clean, reassemble everything. Reverse the steps to put everything back in the car.
TSX cup holder not staying closed
Hi all,
Is there a easy fix for this? when I got the car from Carmax about 2 weeks ago it worked and you can hear the click but not anymore. Is it easy to fix?
Sorry for the confusing title I meant the cup holder lid not staying closed.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
