Hand brake won't release
Old 07-31-2018, 05:15 PM
chckn's Avatar
I parked my 2009 TSX in the garage today and pulled up the hand brake.
2 minutes later, I tried to release the hand brake, but it won't release.
The button barely pushes in, and I've now pulled it up so high trying to get it to release.
Note that over the last 8 months or so, the hand brake button was barely pushing in, but it still worked fine.
Any ideas on how I can resolve this issue myself? Or is this a job for the dealership?
Old 07-31-2018, 07:03 PM
BROlando's Avatar
Received 1,165 Likes on 876 Posts
Pull up lightly to take load off the ratchet. Then push the button.
Or...has the cover sleeve slipped over the button?
Sheefo2k (08-07-2018)
Old 07-31-2018, 07:10 PM
TSXV6Guy's Avatar
Check the rear calipers - one of both could be seized.
Old 08-01-2018, 04:43 PM
chckn's Avatar
The sleeve has not slipped over the button.
The button itself does not push in anymore. It's as if spring inside doesn't spring back.
Old 08-01-2018, 04:44 PM
chckn's Avatar
The rear calipers look pretty normal to me.
What exactly would I be checking?
Old 08-01-2018, 05:27 PM
TSXV6Guy's Avatar
There are levers on each of the caliper, that are actuated by the parking brake cable. Sometimes (often) these levers become stuck (and interfere with the parking brake handle to go back down) . So you need to check manually whether the levers are moving freely - they are spring loaded (i.e. returning to the "release position") when then parking brake is off.
Rear brake
Old 08-01-2018, 05:38 PM
BROlando's Avatar
OP is having issues getting the lever in the cabin to go down.
Like his car took a viagra and now needs to see a doctor due to the effects lasting longer than desired.
Not related to the caliper release
Old 08-03-2018, 01:43 AM
8th Gear
Shiba's Avatar
Old 08-07-2018, 09:27 AM
Sheefo2k's Avatar
Same thing happened to me the other day and I automatically thought of this thread. I hope you got it fixed by now but here's how I ended up fixing mine. I pulled the hand brake handle off and then the button released with no problem what so ever. The issue is the silver release button. It doesn't have room to release once it's all the way up. Once the silver button and e brake handle is removed, then you should be able to release and then re attached the button and handle.
Goodluck
Old 08-07-2018, 09:28 AM
Sheefo2k's Avatar
This guy gets it.
EagleEye
07-23-2013 02:18 PM
inky
04-15-2004 09:35 AM
Quick Reply: Hand brake won't release
