Notices
Fog Light cover
Old 08-06-2018, 12:36 PM
Registered Member
Fog Light cover
Just noticed my fog light cover is cracked, probably smacked by a rock. I see new assemblies for ~$80 that include everything, housing, bulb, cover, etc.
Is it possible to just replace the cover, or do I need the entire assembly?
tmux is offline
Old 08-06-2018, 01:27 PM
Registered Member
Terdbath's Avatar
redline_accessories_USA is an ebay seller with 2012 TSX fogs for $24.99
Terdbath is offline
Old 08-06-2018, 02:24 PM
Registered Member
Thanks. If it's the same process as the 1st gen (could only find vids on 1st gen), looks like I would need to remove the front bumper?
tmux is offline
Old 08-07-2018, 11:17 AM
cu2wagon's Avatar
Received 4,442 Likes on 3,142 Posts
You can finesse your way in on the passenger side through the wheel well, but the intake resonator box is in the way on the driver's side and requires dropping the bumper to get to that one.
cu2wagon is offline
Old 08-07-2018, 12:11 PM
Registered Member
Terdbath's Avatar
Taking the bumper off is not that bad at all. Mine has been removed a handful of times. Once to add the C-mod grill. One more time to take it off and put the stock grill back on and once more to fix a cracked fog myself.
https://acurazine.com/forums/second-...emoval-857385/
Terdbath is offline
Sheefo2k (08-10-2018)
Old 08-07-2018, 12:35 PM
Registered Member
Thanks. Ack, cracked one is on the driver's side. I'd have to commandeer a friend's place too since my garage doesn't allow doing this.
tmux is offline
Old 08-10-2018, 08:13 AM
Registered Member
Great DIY in there. Thanks for sharing. This should come in handy when I am ready to swap in my LED fogs. Good fall project.
Sheefo2k is offline
Old 10-31-2018, 11:07 AM
Registered Member
I recommend putting some covers by LaminX or other brand over them when you’re done- gravel or other things won’t crack them because they are thick 3m rubbery stuff. They are invisible, although I like the yellow tint on my fogs.
TSXWagoneer is offline
Old 10-31-2018, 06:10 PM
Registered Member
2012wagon's Avatar
how difficult ?
Where did you buy?
2012wagon is offline
Glepage22
Third Generation TL (2004-2008)
03-12-2013 11:51 PM
LoveMyTL-S
1G TSX Photograph Gallery
51
01-31-2007 06:55 PM
carib
06-15-2005 02:35 PM
kclai
Second Generation TL (1999-2003)
04-12-2002 05:59 PM
Type S
Second Generation CL Discussion (2000-2003)
29
03-24-2001 07:43 PM
Quick Reply: Fog Light cover
