Notices
DIY Oil Change
Old 08-27-2012, 12:59 PM
  #81
Registered Member
EzeE1o's Avatar
hmm now that i think of it, the filter placement is better on the bottom rather than side mount, at least the oil does not drip on suspension parts/axels, etc. trade off i guess, oil all over those parts or oil all over the filter/hands
EzeE1o is offline
Old 08-27-2012, 01:05 PM
  #82
Registered Member
EzeE1o's Avatar
also, for filter wrench, i used this:
Amazon Amazon
its spring loaded so it can handle virtually any size diameter, and it grips the filter as you turn it counter clockwise.
EzeE1o is offline
Old 09-15-2012, 07:29 AM
  #83
Registered Member
Integra2TSX's Avatar
Originally Posted by robpp View Post
FYI
i went to autozone today and they sold me 5 qts 0w-20 Mobil 1 for the sale price $32.95 with a Mobil 1 filter.
i bought a filter from the stealer so I just got another filter for my old jeep/
cheers!
Originally Posted by EzeE1o View Post
i got a 5 qt jug of 0w20 mobil 1 from walmart for $26, and a bosch filter for $7.
this is my 3rd fumoto valve, on my two other cars, no leaks at all. on the tsx, the protective cover pretty much negates it from being knocked off. and if you bottom out enough to affect the drain valve, you'd probably do more damage to the oil pan too
Guys... Anyone have the part # for the Mobil 1 filter, or any other filter other than Oem? I just figured I'd get it all at autozone etc... Or even walmart
Integra2TSX is offline
Old 09-15-2012, 09:33 AM
  #84
Registered Member
EzeE1o's Avatar
Mobil 1 filter is m1110
Bosch is 3323
EzeE1o is offline
Old 09-16-2012, 01:03 PM
  #85
Registered Member
the_razor's Avatar
can you please do a write up on DIY for B12 service
the_razor is offline
Old 09-16-2012, 03:22 PM
  #86
Registered Member
well, 1 is oil change, seen here and https://acurazine.com/forums/showthr...&highlight=DIY
2 is tire rotation, seen here, https://acurazine.com/forums/showthr...&highlight=DIY
beside that, its just an overall inspection thats more indepth than the A inspection
PyroDave is offline
Old 09-17-2012, 01:07 PM
  #87
SeeYou2Crew #2
ed_423's Avatar
i thought 1 was tire rotation?
ed_423 is offline
Old 09-17-2012, 01:22 PM
  #88
Registered Member
no, 1 is oil, 2 is tire i believe. correct me if im wrong but im almost 100 percent sure of that.
PS: never pay for a air/cabin filter change
PyroDave is offline
Old 09-17-2012, 03:08 PM
  #89
Registered Member
5thTo2nd's Avatar
Factory Recommended Maintenance:Main Item B/B1
Replace engine oil* and filter.
Check parking brake adjustments.
Rotate tires,** inspect for wear and adjust pressure.
Service front and rear brakes.
Inspect parking brake adjustments.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids and check for leaks.
Inspect exhaust system.
Inspect fuel lines and connections.
Factory Recommended Maintenance:Sub-Item 1
Factory Recommended Maintenance:Sub-Item 2
Replace air cleaner element.
Replace dust and pollen filter.
Inspect and adjust drive belt.
So yes, the B1 is just like a regular oil and filter change with a few inspections in there. The 2 is the air filters.
Don't know if you guys noticed but the A service is just an oil change (no filter) so I've known of some dealerships that will just do the fluid without the filter change.
5thTo2nd is offline
Old 09-18-2012, 03:33 AM
  #90
SeeYou2Crew #2
ed_423's Avatar
what would you guys do?
i bought a bosch filter, but bought the wrong one, so im gonna return/exchange it. the bosch filter doesn't come with a washer, should i just go to honda and get a new washer? or just get the oem filter w/ the washer and just return the bosch. i've read the new oem fitlers aren't as good...but i mean, it's OEM. so does it really matter?
ed_423 is offline
Old 09-18-2012, 03:34 AM
  #91
SeeYou2Crew #2
ed_423's Avatar
and do you guys measure the .2 quarts from the markings from the bottle? or do you just guestimate? or you guys have a better more accurate method?
thanks
ed_423 is offline
Old 09-18-2012, 05:45 AM
  #92
Registered Member
thanks
Ed, at that point you're splitting hairs. Oem filter is fine, Bosch is fine. I use saved my 7 dollar Oem filter for maybe next time. The Bosch was 13 bucks...but it's nice though. For washer, just get one at autozone or advanced auto. Cheap.
For .2 quarts guesstimate. I put about a 1/4 bottle in, then let it sit... Sort for 2minutes, then measure. Was perfectly between to dots. Voila.
Old 09-18-2012, 10:01 AM
  #93
Registered Member
EzeE1o's Avatar
put in 4 qts, then start the car for a few seconds, then pour a little more, check the dipstick, pour a little more, check the dipstick....repeat until it is at the top dot
EzeE1o is offline
Old 09-18-2012, 01:17 PM
  #94
SeeYou2Crew #2
ed_423's Avatar
alright thanks guys.
any chance you guys know what size washers i need?
edit: someone mentioned in the 2nd page it's the 14mm washer
ed_423 is offline
Old 09-19-2012, 11:46 AM
  #95
Registered Member
the_razor's Avatar
I found this for cabin air filter: https://acurazine.com/forums/second-generation-tsx-discussion-2009-2014-143/diy-cabin-air-filter-replacement-%2Apics%2A-686281/#post11676433
but searching for DIY for replacing the air cleaner element
thank you
Old 09-19-2012, 11:52 AM
  #96
Registered Member
damaged442's Avatar
I actually enjoy changing the oil on the TSX. It has to be one of the easiest cars I've ever done. Picked up 6 OEM filters with crush washers for $36...I think? 5 quart jug of Mobil 1 at Wally World for $26 and away you go.
The more you guys actually change oil, the better you will get at not getting the oil all over you. Picking up some latex gloves will help. After you spin the filter loose a few times around and it starts dripping, pull your hand away and let it drip for a while, with the catch pan underneath of course. Then, put a rag or ziploc bag over it and take it off the rest of the way.
I also highly recommend anti seize on the lower engine cover bolts, or I guess, now screws. Remember, a little goes a long way. Again, this makes them easier to remove next time.
I also recommend pre lubing the oil filter gasket, which makes it easier to remove next time, without having to resort to pipe wrenches and impaling it with screwdrivers. (I also learned this from experience) and pre filling the filter with fresh oil prior to reinstallation. The oil changing noobs will be ninjas in no time.
damaged442 is offline
Old 09-19-2012, 12:51 PM
  #97
Registered Member
5thTo2nd's Avatar
I found this for cabin air filter: https://acurazine.com/forums/showthread.php?p=11676433
thank you
i was going to writeup a DIY for this too but it's really so easy there's no point. Just pop the hood, locate the airbox and unclip the 4-5 retaining clips and replace the old filter with the new one...honestly takes longer to type this out than actually do it.
5thTo2nd is offline
Old 09-19-2012, 06:58 PM
  #98
Registered Member
the_razor's Avatar
I get the part loosin the four bolts then does the cover open up easily or any tricks in this?
thnx
Old 09-19-2012, 10:04 PM
  #99
Registered Member
thnx
there are no bolts. pop your hood, prop it up, on the right side theres a big square box thing, there are 5 hook type clips. 2 towards the front, 2 towards the back, and one toward the inside of the engine bay. just put your thumb under each and push away from the box. pull the top up a few inches, pull out old filter. put in new filter in the same position, place the top down, secure the clips. done.
PyroDave is offline
Old 09-20-2012, 09:08 AM
  #100
Registered Member
Puppetmaster's Avatar
Thanks for the writeup, used it when I changed my oil a month ago, and everything went smoothly. Definitely useful for everyone.
Puppetmaster is offline
Old 09-22-2012, 03:42 AM
  #101
SeeYou2Crew #2
ed_423's Avatar
finally did my oil change!!
my friend's jack wasn't that great though, so it won't fit the side and wasn't long enough to jack from the front
so had to resort to this
ed_423 is offline
Old 09-22-2012, 03:04 PM
  #102
Summer is Coming
Rocket_man's Avatar
This was just to get the jack under the car right? You didn't actually get under a car while it rested on a few 4 x 4's?
Rocket_man is offline
Old 09-22-2012, 03:05 PM
  #103
SeeYou2Crew #2
ed_423's Avatar
oh no definitely not! that was just to get the jack under so we can put the car on jack stands
ed_423 is offline
Old 09-23-2012, 06:55 AM
  #104
Registered Member
i love my rhino ramps!
its rayden is offline
Old 11-07-2012, 09:50 PM
  #105
Registered Member
odd question, but how many miles do you guys go in between oil changes? i have traveled almost 5K highway miles since my last one (lots of highway) and oil life is still at about 70% per the gauge cluster.
also i have a honda dealership that is almost next to my house, what filter do i ask them for that will work on my TSX K24z3? 8th gen accord?
fiebru1119 is offline
Old 11-08-2012, 03:25 AM
  #106
Registered Member
they'll know what filter. small tidbit is that every single acura uses exactly the same filter. they are interchangeable. i figure that holds true for honda
PyroDave is offline
Old 11-08-2012, 07:28 AM
  #107
Registered Member
Last time went 9800 miles before the oil change. Roughly 80% highway. Oil life indicator was showing 15% at that point.
Novichek is offline
Old 12-30-2012, 01:55 PM
  #108
I Spit On You.
Mercedes>BMW's Avatar
Can anyone tell me which filter to get? Thanks
Mercedes>BMW is offline
Old 12-30-2012, 07:12 PM
  #109
Registered Member
stan_t's Avatar
OEM works well for me and it's cheap. I get the Honda oil too, which seems to work well as well, and is also fairly cheap. I don't see good reasons to use anything else at the moment.
Stan
stan_t is offline
Mercedes>BMW (12-31-2012)
Old 12-31-2012, 12:13 AM
  #110
Registered Member
coffee filters work fine.
PyroDave is offline
Old 12-31-2012, 09:22 AM
  #111
Graphite Ghost
not sure what rhino you have but I cant drive my TSX wagon front wheels onto them without hitting something.
I was able to back up onto them to do my RSB but not the front?
robpp is offline
Old 12-31-2012, 09:35 AM
  #112
Registered Member
Stan
Agreed. OEM filters are great and with the right contacts, you can get them in bulk for super cheap. And isn't Honda/Acura oil just Mobile One?
Old 07-14-2013, 08:05 PM
  #113
Registered Member
Originally Posted by TSXKid2010 View Post
Just a little update:
I had to replace my undercover recently. I got genuine Acura parts, and apparently these new covers us screws instead of bolts. Maybe this happened in the MY change, IDK. can any of the 2011+ guys confirm this?
Just did my first oil change on my '12 SE this weekend. Was surprised to see these screws. The '11 Sport Wagon I had still used bolts. The screws were a pain, because they screwed into something flexible, so the stuff just flexed and the screwdriver would slip. I had to use an impact driver to get them out.
scheißterhöffer is offline
Old 07-15-2013, 11:06 AM
  #114
Registered Member
Does anyone else do what I do?
I buy an extra 4 quarts of cheap oil, after I drain out the dirty oil, I pour the fresh 4 quarts of cheap oil in, let the car run for 15 min, then drain that crap out, then I replace the filter and add the mobile1.
It seems like overkill but I enjoy knowing it is flushed each time, I also have a magnetic drain plug.
BattleofXs is offline
Old 11-19-2013, 01:13 PM
  #115
Registered Member
Thanks for the DIY...looks easier than changing the oil on my RSX with the filter being on the bottom instead of the side.
I just bought my TSX on Saturday at a dealership in Chicago, but I already want to change the oil because 1) The dealer overfilled it (the oil on the dipstick sits about 1 inch above the top fill line) and 2) I'm not sure if they used synthetic when it was just serviced.
JayJayPG is offline
Old 11-19-2013, 03:24 PM
  #116
Registered Member
jonnys_honda's Avatar
I was as skeptical as you were when I bought mine used with 48K mi. I checked the dipstick and the oil did not look new. I drained it and used a synthetic blend, did the transmission and brake fluid while I was at it. Nothing beats peace of mind!
jonnys_honda is offline
Old 11-20-2013, 04:16 PM
  #117
Registered Member
ejongjin's Avatar
There is nothing better than keeping peace of mind!
ejongjin is offline
Old 12-22-2013, 11:36 PM
  #118
Registered Member
I apologize for reviving an old thread, but I just brought in my vehicle into the dealership for an oil change. 2013 TSX Tech Package Automatic with 4k miles. The service manager there said that the indicator states 40%, therefore there is no need to change the oil.
So, I am used to having the interval of 3-4k miles per oil change on my 2002 accord.
The service manager tells me:
"That is the old way way of oil changes, now the intervals are no longer needed, but rather just change when the indicator shows up that a oil service is due. Also, if I do want to do an oil change right now before the indicator shows up, all the A1 codes will also be cleared, so they will not show up anymore."
Is what the service manager described accurate??
I am skeptical, but I am definitely not knowledgeable.
I appreciate anyone that can provide some insight.
Thanks in advanced.
advaivce is offline
Old 12-23-2013, 01:51 AM
  #119
TSX AMG Type //M i-VVT
iCrap's Avatar
Yeah that's what my guy said too.
the interval he said is 5-6k.
iCrap is offline
Old 12-23-2013, 09:49 AM
  #120
Registered Member
Thanks in advanced.
I've been told the same, after 5K miles (40%). They said " you are wasting money ", to which I replied "it is MY money, so just change the oil and filter".....they did.
fxcarden is offline
Quick Reply: DIY Oil Change
