DIY Oil Change
13 Attachment(s)
I thought I'd put together a little DIY of the most simple of maintenance procedures since there isn't one so far for the 2nd gen. Personally I like doing as much as possible on my own. It saves money (more money for mods!), is almost just as fast if not faster than going to the dealer and makes you appreciate your ride more.
That said, things can still go wrong like a jack failing, over-filling the oil, etc so if you don't feel comfortable doing this yourself then get a shop to do this. Tools Needed:
Remember to dispose of your used oil at a proper dumping facility. Some shops also take old oil. Here is the MID indicating that an oil and filter change is due: Attachment 52252 Gather all your gear together: Attachment 52253 Set the parking brake and jack up the car on a hard, level surface (concrete preferred, asphalt is too soft). Block the wheels that are still on the ground. Set your jack stands at the appropriate jack points and get under the vehicle and locate the under cover that we're going to remove. Grab your 10mm socket and remove these 3 bolts closer to the passenger side of the vehicle: Attachment 52254 And these 4 bolts closer to the driver's side: Attachment 52255 Remove the undercover and set it aside: Attachment 52256 Pop your hood and remove the oil cap. Go back under the car and locate the oil filter and drain plug (there's an arrow pointing to the drain plug and it even says Engine Oil so you can't mess this part up): Attachment 52257 Closeup: Attachment 52258 Those damn grease monkeys at the dealership always over-tighten both the filter and the drain plug--that's another reason I like doing this myself. Remove the drain plug and filter and let it pee into the oil catch pan: Attachment 52259 Honestly I don't know how those 30min oil change places do it...I let mine drip for at least 15-20 min to get all the old crud out. While you're waiting you might as well do something productive. Some people like to clean out their air filter or something like that. I take this time to prime my new oil filter by filling it with clean oil and clean up my oil drain bolt and make sure that I replace the old crushable washer with a new one. Take a little fresh oil and grease up the new gasket around the oil filter. Attachment 52260 Attachment 52261 Place the old filter into a ziplock bag and empty the old oil into a suitable container (I use old oil jugs). Go back under the vehicle and re-install the oil drain plug (with crushable washer) and filter. Make sure the old filter gasket came off with the old filter. Tighten the drain plug to 29 ft lbs. Hand-tighten the oil filter. Grab your funnel and fill the engine with 4 litres your favorite brand of 5w20. Check the dipstick after you've let the oil settle and then replace the oil cap. Attachment 52262 Go back under the car and re-install the undercover. Make sure to have the front of the cover go into this slot. You'll know what I'm talking about when you see it. Attachment 52263 Remove the jack stands and lower the vehicle. Get into the car and start it up. As per the owner's manual, if the oil pressure light does not go off in 5 seconds then turn off the car and check your work. I like to let it idle for a few minutes then check for leaks and re-check the oil level. I also take it for a quick spin and re-check the level. Hold down the reset button on the steering wheel and reset the MID and you're done. Attachment 52264 Congrats that's it! This was my first time doing an oil change on this car so it took a bit longer (90 min) but it should only take 45 min or so once you're used to it. :thumbsup: |
This needs sticky status
Nicely done bro! Always wanted to do it myself now I know how |
Sticky and rep for this awesome DIY pls. These always go under appreciated.
Thank you 5thTo2nd for the excellent write up.
perfect timing, service b1 light just turned on for me.
shawn keep in mind that b1 includes some other service beside oil change. tire rotation, along with a more detailed check of stuff like brakes
great write up! i might just try this when i get the tools needed!
Awesome write up! Might do it when the Oil life goes down more. i think im at 50%
i would start the car and check for leaks before reinstalling the undercover and lowering the car
Yeah it's not hard at all. Actually, it's probably the easiest car I've ever done since the location of the filter is so convenient. Some cars have the filters in the crappiest places.
For B1 you can rotate your own tires too if they're not directional. Rotation pattern is in the manual. Even if they're directional, you can move front-to-back for the time being and then do a proper rotation later. Brakes can be eye-balled. Yeah, definitely check for leaks before the cover is back on LOL! I'm just used to starting up the car last cause my previous cars were all stick and I had to lower the car before getting in and depressing the clutch. |
@OP, I give you 10 for the in-detail instructions and I give you an additional plus (+) for this statement: Take a little fresh oil and grease up the new gasket around the oil filter.
As I read through your instructions, I wait for a chance to knock off some points on particular trick but obviously, you are good :) Not whole lot of people who diy knows this little trick. Another trick is instead of dispose the crushable washer, you can just flip it and reuse one more time but who care since it's dirt cheap and often comes with when you purchase the genuine Honda oil-filter. Thumbs up for you. |
Originally Posted by pinatubo
(Post 13140205)
As I read through your instructions, I wait for a chance to knock off some points on particular trick but obviously, you are good :) Not whole lot of people who diy knows this little trick. Another trick is instead of dispose the crushable washer, you can just flip it and reuse one more time but who care since it's dirt cheap and often comes with when you purchase the genuine Honda oil-filter. Thumbs up for you. Nice trick on the crushable washer! Another thing some people do to save some coin is to change the oil filter every other oil change. I've always changed everything cause I figure it's just a few bucks more. |
what you guys think of the Mobil 1 Extended Performance
does our TSX need that or stick with the regular Mobil 1 |
Correct me if I'm wrong, but I thought our cars need more than 4 quarts of oil. I think the manual says 4.4 quarts. People in the 1st gen forum say theirs takes as much as 5 quarts.
Originally Posted by the_razor
(Post 13143536)
Originally Posted by No1nfoProvided
(Post 13143779)
Originally Posted by 5thTo2nd
(Post 13144678)
Yeah I was pretty surprised too at how little the oil change capacity is. I just double-checked the owner's manual and it says 4.2 US quarts, or 4.0 litres. That just means we don't need to buy as much oil. :)
^We Canadian are used to Metric and SAE measurements, heck, we have both English and French as Official Languages.
But to our American members: 1 Quart = 0.946352946 Liters. So 4 litres = 4.226753 Quart |
Originally Posted by 09TSXTech
(Post 13145659)
(Post 13145924)
Haha. I wish the US switched over to the metric system like the rest of the world. I shoulda known better, tbh. I work in a lab and all of our measurements are in liters and stuff. I don't understand why the US has to do things differently, like drive on the right side of the road and whatnot.
You should have no problem using old oil (after all it was in the ground for thousands of years anyways right). The only thing I know of to use fresh is brake fluid since old bottles can absorb moisture which can affect braking effectiveness. |
I had my oil changed today by the dealer. I went there because when I priced the oil, I would've spent more on the oil than I would have at the dealer, not to mention the time. Turns out, they didn't charge me for the service.
Quick question, my MID only showed "B", not B and a number. Is that normal? |
Originally Posted by MyBabysBaby
(Post 13197646)
Quick question, my MID only showed "B", not B and a number. Is that normal? As for the number, it doesn't show up every time. 1 just mean tire rotation, 2 means air and cabin filter change, 3-transmission fluid change and 4 means spark plugs and timing belt. Just check/refer with your owner's manual. |
1 Attachment(s)
Sorry for the very OT question, but would anyone happen to have the part #s for those 7 bolts holding the cover on this pic? TIA
Attachment 52100 |
Originally Posted by itr_1211
(Post 13213738)
http://i3.photobucket.com/albums/y64...e/DSCF5142.jpg If you ever need to find out part numbers look up Honda's e-store: http://estore.honda.com/acura/parts/...-4-tsx-5at&dl= |
Great write-up! Hoping all is well, I've been busy with school and Jeep Wrangler shopping :D. I've two more free oil changes from the stealership before I start doing my own changes on the TSX!
Originally Posted by s40 driver
(Post 13214070)
Two free oil changes takes you pretty far...you probably won't be DIY'ing till mid next year! |
^ They don't give free oil change here in BC.
5thTo2nd, maybe you should get a SE badge on yours. |
Great post! Any person can read this and not mess this up!
I'm too lazy... I get a coupon every two months from the dealer for a $29.95 oil change and car wash.
(Post 13216748)
thanks! Hope you're enjoying your Type S kit as much as I am. Who's the Jeep going to?
Two free oil changes takes you pretty far...you probably won't be DIY'ing till mid next year! I am replacing my '08 Ranger with the Wrangler and my better half will be using it as a primary vehicle. I am going to pick the Jeep up on Saturday and looking forward to it! Yeah, I've had my TSX for a little over a year and should be due for the second oil change within the next month or two. I'll be well prepared from this write up if I end up having to do changes myself sooner though. Thanks again! |
i'll be changing my oil tomorrow, i really appreciate this DIY. just bumping it up incase anyone else needs it. really should be stickied(mods please)
also, this is the part number if anyone needs it for the oil filter. 15400-PLM-A01 they are about 7 bucks from any acura dealer |
Just did my first one at 8500 miles, oil still said 30%. I went ahead and changed it since that's the longest I've ever ran oil.
I will say this car is incredibly easy, the filter is right there. On my old civic I had to do it blindly with the filter-wrench up since the filter was higher on the block. |
Originally Posted by ddcd
(Post 13665695)
Originally Posted by PyroDave
(Post 13665680)
also, this is the part number if anyone needs it for the oil filter. 15400-PLM-A01 they are about 7 bucks from any acura dealer I heard pretty good things about the HAMP (green) filters for Hondas but they're pricier so I never bothered.
Originally Posted by MoaarLow
(Post 13666488)
Sheeesh! 8500 and still at 30%. Im blown away that im at 40% and have 3500 miles. At this rate i should get ~6000 miles out of this oil. With my previous car i was changing oil every 2000 miles. Gotta love this!! Nice DIY. An oil change is something every enthusiast should be able to do. Really simple and gets you and your car to spend some quality time :)
(Post 13666488)
(Post 13136506)
Hi! Thanks for the tutorial
Can you explain more what is the Oil Catch Can for? The Oil filter part #:: 15400-PLM-A02 is also good for use, isn't it? Thank you |
Originally Posted by t33h00
(Post 13668125)
Can you explain more what is the Oil Catch Can for? The Oil filter part #:: 15400-PLM-A02 is also good for use, isn't it? Thank you apparently a01>a02. you can get ao1 with crushable washer for $7.75 from any acura dealership. i actually got 2 for 1. the guy that did my brake change a few weeks ago got awarded top tech for the region, so i told him congrats when i stopped in today. the GM overheard, told the Service Manager to call me, i was still on the lot, he told me to come back. and he gave me a second oil filter free compliments of the GM. it wasn't an expensive loss for him, but small gesture that i truly enjoyed. i'll be emailing him ASAP |
Nice write up on the procedure. Only one thing I would add is- anti-seize the under-cover bolts if you live in the rust belt like I do. I had one seize up and it was a bitch to get it out.
Just a little update:
I had to replace my undercover recently. I got genuine Acura parts, and apparently these new covers us screws instead of bolts. Maybe this happened in the MY change, IDK. can any of the 2011+ guys confirm this? |
Originally Posted by TSXKid2010
(Post 13669129)
