DIY- HVAC Display Color Change (Easy)
Old 02-28-2015, 08:05 PM
ROTAREDOM
ssjoeboe9's Avatar
Received 1,488 Likes on 1,058 Posts
I've been wanting to do this for a while now, I saw someone do it on the [other forum] a while back, but finally decided to tackle the project on my own. I bought an extra display unit on ebay for super cheap, that way I wouldn't mess up my original display.. It turns out that I didn't need it, but I think the discovery was worth the amount I paid.
Originally I was going to replace the 16 in-line LED's on the HVAC display with new Red LED's. I spent about 2 hours carefully de-soldering the original LED's and trying to replace with the new Red LED's, but they are so tiny and the solder pads on the PCB were coming detached.. and it was really frustrating trying to align and solder everything. Then it hit me, to just apply film across the white LED's.
So that's what I did, and Ill outline below...
Take your HVAC display out by carefully working around the edges of the plastic and foam panel with a flat head, or something to pry with. Gently separate the foam from around the display until there is enough gap to pull it out. It's only mounted by 4 clips.
The back side of the display is held on by 4 screws and mounting tabs on the side. Take those out and you'll see the back side of the PCB. It's held on by 2 screws.
Take the 2 screws out and flip it down. You will see the line of 16 LED's at the bottom. Cut a strip of vinyl (color of your choice-I used left over vinyl from when I tinted my turn signals red) and apply over LED's.
That's it, now screw everything back together and plug it in. You'll probably notice there is a slight drop in brightness, but the color change for brightness is worth it in my opinion. Photos of my completed install below.
Hope this helps out anyone else who was wanting to do this!
xtcnrice (03-01-2015)
Old 02-28-2015, 09:05 PM
TSX AMG Type //M i-VVT
iCrap's Avatar
i was considering doing mine blue....
how much HP did this add?
The following 2 users liked this post by iCrap:
opboarding (03-01-2015), urbanstereo (03-27-2015)
Old 02-28-2015, 09:38 PM
Unregistered Member
Harper's Avatar
We will never know since Joe totalled his car.
The following 2 users liked this post by Harper:
iCrap (02-28-2015), MC MiYoung3269 (03-10-2015)
Old 03-01-2015, 12:28 AM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
Nice job Joe!
Old 03-01-2015, 10:03 AM
ROTAREDOM
ssjoeboe9's Avatar
Btw, if anyone is interested in the extra display I have PM me. If you are good with soldering/repair of PCB components then this should be fairly simple. I'll include all the original white LED's and the red ones (if you want them).
Old 03-01-2015, 11:17 AM
iCrap's Avatar
how much do you want for it? and how broken is it?
Old 03-27-2015, 11:31 AM
BothKneesDown's Avatar
Dang you guys keep giving me more and more ideas.
But i especially like this one since it's near free
02-25-2020 09:57 AM
snorf
11-04-2019 06:44 AM
PortlandRL
09-14-2015 12:01 PM
Aleax
09-11-2015 11:31 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
Quick Reply: DIY- HVAC Display Color Change (Easy)
