Notices
courtesy lights front door's
Old 11-13-2017, 08:39 AM
Registered Member
good day the courtesy lights of the front doors, ie pilot and co-pilot do not work, initially they had factory lights, changed them to LED and ran for a while, the pilot light was the one that failed first, when failure changed the LED and even so it does not work, check all the fuses and all are well, check voltage and between positive and negative focus socket, I have no voltage (12VDC), a rare detail is that the focus of the passenger door stays on but as only 15-20% of its capacity and I press the switch and it does not turn off it stays on even when the vehicle is working, I think I have two or three options to check: 1.- check the switches on the door frame 2.- the socket wiring 3.-The harness together with the module that controls the lights. If someone had this problem or something similar, I would appreciate your help. Thank you.
luishk416 is offline
Old 05-16-2018, 01:02 AM
Registered Member
I had this issue with my driver side door. Removed 98% of the paneling on the door and everything looked good. I grabbed the wire harness and squeezed and jiggled wires. It didnít work. In discouragement i shut my door and opened it again and holy crap it worked. Lol. Best advice i could give with a similar situation
Kbrennan is offline
luishk416 (05-16-2018)
Old 05-16-2018, 08:43 AM
Registered Member
I will try to do what you tell me, maybe it works, one more question, you had the original lights or you had changed for another type, for example led. Greetings.
