luishk416 |
11-13-2017 08:39 AM |
courtesy lights front door's
good day the courtesy lights of the front doors, ie pilot and co-pilot do not work, initially they had factory lights, changed them to LED and ran for a while, the pilot light was the one that failed first, when failure changed the LED and even so it does not work, check all the fuses and all are well, check voltage and between positive and negative focus socket, I have no voltage (12VDC), a rare detail is that the focus of the passenger door stays on but as only 15-20% of its capacity and I press the switch and it does not turn off it stays on even when the vehicle is working, I think I have two or three options to check: 1.- check the switches on the door frame 2.- the socket wiring 3.-The harness together with the module that controls the lights. If someone had this problem or something similar, I would appreciate your help. Thank you.
