CD Player Removal
CD Player Removal
My cd player has a cd stuck in it and it's make alot of noise. So I need to remove the cd player and take out the Jammed cd. I've Searched AcuraZine And The Internet with no luck. anyone have a DIY description on how to do this?
Not sure if you have ELS or Premium audio, this is for premium, and it looks like it many pages long, with each section referring do another section
1 -wear gloves, cover everything w towels so you don't scratch things, get all your codes and radio presets written down.
2 - remove center console (reference 1) and passenger dash trim (reference 2)
3 - remove drivers center trim and passengers center trim( ref 3)
4 - remove climate control (ref 4) and center pocket ( ref 5)
5 - disconnect bolt, under big knob, facing up, and pull head unit out
6 - disconnect connectors (5 or 6)
7 - remove dash center vent (ref 6)
8 - separate audio unit from faceplate (screws and bolts)
Reverse to install
I don't have time for the references
The ELS is a bit less, don't see the quick differences
Reverse to install
TasteOfPower
1G TSX Problems & Fixes
10-03-2014 08:20 AM
NYbsbl04
04-13-2005 08:20 AM
