CD Player Removal
My cd player has a cd stuck in it and it's make alot of noise. So I need to remove the cd player and take out the Jammed cd. I've Searched AcuraZine And The Internet with no luck. anyone have a DIY description on how to do this?
Service manual says replace the head unit if the CD won't eject. I $#it you not.
Not sure if you have ELS or Premium audio, this is for premium, and it looks like it many pages long, with each section referring do another section
1 -wear gloves, cover everything w towels so you don't scratch things, get all your codes and radio presets written down. 2 - remove center console (reference 1) and passenger dash trim (reference 2) 3 - remove drivers center trim and passengers center trim( ref 3) 4 - remove climate control (ref 4) and center pocket ( ref 5) 5 - disconnect bolt, under big knob, facing up, and pull head unit out 6 - disconnect connectors (5 or 6) 7 - remove dash center vent (ref 6) 8 - separate audio unit from faceplate (screws and bolts) Reverse to install I don't have time for the references The ELS is a bit less, don't see the quick differences |
