Brake Lights
Old 08-19-2018, 11:00 AM
3rd Gear
gnaff9093's Avatar
Brake Lights
Hello!
I am brand new to Acurazine and have looked all over for help with replacing the fuse that has obviously blown that now my brake lights do not work whenever I apply the brakes. However, the third (in back window) works fine, thankfully. Where do I find the fuses, which one is it and where can I buy the fuse? Of course, this is my analysis; that the fuse is blown. My conclusion since both stopped working suddenly. Thanks so much!
Old 08-19-2018, 01:49 PM
fbt
fbt's Avatar
https://acurazine.com/how-tos/a/acur...diagram-426580
and you can buy the fuses at any auto parts store
gnaff9093 (08-19-2018)
Old 08-19-2018, 02:59 PM
3rd Gear
gnaff9093's Avatar
Thanks. I have yet to find anything on the internet even extensive searches in Google, etc that tells me which of the two fuse boxes houses the brake light fuses. There's everything under the sun on this except what I need. I need to know which of the two fuse boxes is this located. All the diagrams I have seen, not one has a label or diagram that identifies a fuse for brake lights.
Old 08-19-2018, 03:27 PM
fbt
fbt's Avatar
There is no single fuse for rear taillights. I'd guess it would be "Small Extr L" pull it and see if it's broken. If not pull another. If none are broken then you are going to have to check the wiring. There may also be a inline fuse to the rear lights.
Old 08-19-2018, 07:52 PM
TSXV6Guy's Avatar
Dumb question, but... Did you check the bulbs.....?
Old 08-20-2018, 02:20 PM
BROlando's Avatar
Received 1,163 Likes on 874 Posts
How do you know they both went out together? Maybe they burned out sequentially...but you just noticed it recently.
Old 08-20-2018, 06:02 PM
RTM
RTM's Avatar
They (according to fuse box) are called STOP lights, not brake lights (whose idea was that?) Think they are #12 or #13.
And I think they are all on the same fuse, so I too would agree on bulbs.
Old 08-21-2018, 10:52 AM
BROlando's Avatar
If the fuse is indeed blown...
WHY did that happen?
Old 08-21-2018, 05:08 PM
Acura Fanboy
knavekid's Avatar
Download the factory service manual PDF for your TSX. The wiring schematics will allow you to troubleshoot your issue and identify any fuses involved. Find it here:
https://www.tsxclub.com/forums/2nd-g...l#post50360497
Amoeba
03-02-2014 07:58 AM
EagleEye
07-23-2013 02:18 PM
jblanton007
11-10-2011 11:13 AM
deepblue626
09-23-2009 09:10 AM
deepblue626
09-22-2009 04:05 PM
Quick Reply: Brake Lights
