Notices
Bluetooth HFL module location
Old 10-07-2016, 08:02 PM
New Member
Exclamation Bluetooth HFL module location
I'm having trouble with my Bluetooth HFL draining my battery after a few days parked. I just recently changed my battery and it seems to have drained that already. Does anyone know where the bluetooth HFL is located for an 2012 Acura TSX?
Steven Chan is offline
Old 10-09-2016, 06:03 PM
Registered Member
Why do you think is the HFL unit?
In any case, see the images for the location.
Attached Thumbnails Bluetooth HFL module location-hfl-1.jpg   Bluetooth HFL module location-hfl-2.jpg
Guanacoracing is offline
Old 11-02-2016, 09:43 AM
Registered Member
I've heard about this being a problem before and the HFL being a parasitic draw when it goes out. Were you able to disconnect it? if so, did it resolve the issue?
edwinwng is offline
Old 11-02-2016, 09:47 AM
Received 5,846 Likes on 4,687 Posts
It's definitely an issue on the 3rd Gen TL's not so sure about the TSX though.
Have you don ea parasitic draw test to determine where it is before randomly pulling things?
Does your HFL work?
thoiboi is offline
Old 11-22-2016, 11:56 PM
New Member
it's the panel right above your feet on the passenger side.. It's directly attached to it. You can leave it disconnected if you would like to test for parasitic draw.
I permanently disconnected mine after I put in a aftermarket stereo with steering wheel controls (including call and hangup functionality).
anjayk is offline
Old 02-18-2019, 05:30 PM
New Member
Blue tooth module
[QUOTE=Steven Chan;15867571]I'm having trouble with my Bluetooth HFL draining my battery after a few days parked. I just recently changed my battery and it seems to have drained that already. Does anyone know where the bluetooth HFL is located for an 2012 Acura TSX?[/QUOTE
did disconnecting the blue tooth module fix your problem? I'm having same issue with my 2011 tsx? Where is the module located?
nmarcel1 is offline
Old 03-18-2019, 12:36 PM
New Member
Do you know what wire from the steering wheel control module too hook up too the hfl the diagram info i got says its the orange in pin 2 for analog please help
acura life is offline
MikeILX
Acura ILX Discussion
07-07-2018 10:49 AM
RedneckCPA
03-09-2017 08:05 PM
jglover
09-07-2016 07:25 PM
slickrab
05-09-2016 09:37 PM
paperboy42190
01-24-2016 06:05 PM
Quick Reply: Bluetooth HFL module location
