Autocross
Autocross
Anyone else autocross their TSX and have a hard time sitting up right with a helmet on?
I'm 5' 11.75"... have to recline the seat more than I'd like to to clear the headliner enough when wearing a helmet.
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeek!
It's been suggested to me. It is my DD though so I'm not wanting to do something like that...
I'm also guessing that pretty much all SA2010/2015 helmets are going to have similar casting sizes. Too bad no one makes rails that are a little lower for our seats...
t3hhcaptain (07-07-2017)
Yeah, me too!
This is with the seat all the way down?
I'm 5'11 and have plenty of head room. But...I have long legs/shorter torso, and am skinny like a somali pirate...so my butt does not elevate me.
side note; ever since I got my car, i've had a hard time adjusting to the clutch. all my friends laughed at me and called me a noob because i couldnt drive smoothly.
it's only this year that i adjusted my seat....and holy crap, i drive a lot better!!!!
it's cuz my short legs cant reach the pedals.
TSX clutches grab too GD low. I have a K20A clutch/flywheel in mine.
justnspace (07-07-2017)
The TSX handles well. Its as long as a yacht...so its not flickable....but it should at least stick.
There's things you can do for better rotation and turn-in without sacrificing ride quality much/at all.
I can't imagine wearing a helmet in my TSX
Pretty well. Everyone in here apparently has a 6MT but I have a 5AT. I use the sport shift mode and it stays in the power band well. I also have some upgraded suspension components that help in corners and slaloms.
I also pump the tires up real nice like.
I think the suspension MR is 1.6:1 front and 1.15:1 rear?
Weight split is 60/40?
To have an equal roll (wheel) rate, one would need rear springs about 52% as stiff as fronts. A 800LB front spring and a 416LB rear spring, for example, would provide the same roll stiffness.
But again...60/40 split in TOTAL weight. And sway bar rates, etc.
Would need to isolate sprung weight for spring rates...and unsprung weight coupled with spring rates for deriving damper rates.
Its complex like a MF.
Just try a buncha different springs/bars like a hill billy. I would.
But stiffer rear springs make for a shit ride, M8.
I'd rather just do camber kits, staggered tyre sizing, and a bigger rear sway bar.
Itz JDM y0!
I Autocross mine, I'm 5'8" and don't have a problem with the helmet.
As for performance I usually set lap times similar or a tiny bit faster compared to the Accords/Camrys/Altimas which is expected I guess. Only things I have for handling are Pilot Sport AS/3 tires and Progress swaybar, but there's no way trying to mask the fact that it's a 3500lb fwd car. Car is pretty fun tho. Best mod you can do is driver mod.
xtcnrice (07-12-2017)
Former Sponsor
If you really want to make yourself fit in the car helmet and all then you should think about replacing the OEM seat.
If you're not looking to spend too much you could get a fixed back bucket seat (since those tend to be cheaper then their reclineable counterparts) and a flat floor/side mount bracket and you should fit much better.
Something like the Corbeau Forza is $240, FIA Approved, and feels super solid! Planted makes brackets and mounts, and that should be it! You can even set it up to run the stock seat belt so you won't need to get a harness too.
If you wanted some pricing and availability feel free to send me an email at performance@excelerateperformance.com and I can help you!
I just need to figure out a way to shave a few inches off my height while remaining uninjured and functional.
I (summer) daily drove my S2000 and drove across country with Recaro fixed buckets. They're arguably more comfy than most stock seats. Obvi... not heated, power, etc. I don't recline (though I did design my own sliders, and had the side plates CNC'd to put the seat at the perfect tilt).
The problem is that aftermarket sliders succ (which is why I just designed my own). I won't say I had experience with the Planted ones. But my Buddy Clubs were fu#&ing terrible, M8.
Maybe use a fixed bucket for summer during autocross season...and then switch back to stock for off-season? Its not too hard to switch.
One thing to be weary of when tracking your car- your brakes. the TSX doesn't have sport brakes, so you NEED to make sure you have fresh brake fluid, otherwise you'll get brake fade even faster and it'll kill your fun. That being said, you'll likely suffer brake fade anyway... a friend of mine went to the track with me a couple weeks ago. He brought his 4G TL SH-AWD 6MT out, and man, after 20 minutes, when he pulled back into the pit, his brakes were literally smoking up front. He had brake fade start at about the 10 minute mark, and it would get worse over time.
im not trying to sway you from going- it's still very fun and exciting.
Also, when you're done lapping, be sure to NOT engage your e-brake, or even keep your foot on the brake pedal (this goes for any car). Your pads will fuse to the rotor, from how hot everything gets. Pull in, shut the car off and leave it in gear. All will be well.
These days, I unbolt my seats when doing a thorough clean of my cars. Nothing more annoying then not being able to get the vacuum into all the nooks and crannies, or beating up the plastic trim everywhere, trying to get the vacuum into the tight spaces.
It might be be worth investing in a used or cheap racing seat. Planning on doing a track day, just swap it and go. You're only issue will be figuring out the seat rails, but I imagine there are options out there.
Autocrossing doesn't really tax the brakes. Tracking does. In either case, a good brake pad set does wonders. Blank rotors. Good fluid. Even something "common" like Valvoline Syntheic or Castrol GTLMA if you want a step up.
Stoptech sport pads (or similar) would be MORE than enough for autocross. Honestly...they may work on a track too...but I can't promise that. The TSX is heavy...but also slow. But also...heavy. With relatively small brakes.
Hawk HP+ makes for an excellent autocross pad because of its cold torque. But the dust is corrosive, along with other streetability issues, so they probably won't work for a daily driver. They're NOT track pads, though.
There are tons of actual track pads out there. None are streetable.
