Notices
2012 transmission fluid filter
Old 10-13-2018, 01:52 PM
Registered Member
Is the filter accessible/can it be easily replaced? If yes, does anyone have a part # and link to instructions/DIY video?
Thanks.
Skipswift is offline
Old 10-15-2018, 05:40 PM
Registered Member
SharangCU2's Avatar
I believe the transmission filter on the 2009+ TSXs is built inside the transmission and can't be changed. It's supposed to last the life of the car.
SharangCU2 is offline
Old 10-15-2018, 05:44 PM
Registered Member
That's what I've read to but I've also read that there is an in-line filter that can be replaced by removing the hoses and reconnecting the hoses to the nww filter. Wondering if maybe there is a secondary filter.
Old 10-15-2018, 06:16 PM
Received 5,841 Likes on 4,683 Posts
thoiboi is offline
Old 10-17-2018, 10:35 AM
Registered Member
I've swapped it. It's a real pain getting the hose on the back side off, but it's doable. Basically just disconnect the hoses, take off the old one, install the hoses on the new one.
t3hhcaptain is offline
Old 10-20-2018, 06:15 PM
Registered Member
At 107k, figured I'd order one and get this done. Should be able to do it next week.
ImBroke is offline
Old 12-31-2018, 03:11 PM
Registered Member
Picture of in-line filter?
Thanks. Any chance you can send a pic of where the filter is located? Can't seem to find it in the engine compartment.
Old 12-31-2018, 03:15 PM
Registered Member
TSX part number?
Appears to be a LT part. Do you have a link or part number for the TSX? Want to make sure I am ordering the correct part.
Thanks in advance.
Old 01-08-2019, 09:38 AM
Registered Member
I can try to take one later... but, it's very close to the firewall, and on top of the transmission.
Thanks in advance.
https://www.oemacuraparts.com/v-2009...-atf-pipe-l4-1
Part #4, 25430-PLR-003
Old 01-08-2019, 01:06 PM
Thanks in advance.
Whoops, my bad, was in the wrong subsection, but luckily, both the TSX and Tl share that part number
thoiboi is offline
Old 02-07-2019, 07:16 PM
Registered Member
Thanks t3hhcaptain -- any luck with that photo? Appreciate it!
thefork
Second Generation RL (2005-2012)
08-21-2011 02:15 PM
thelastaspec
Second Generation TL (1999-2003)
06-13-2011 12:59 AM
Putthead
Third Generation TL (2004-2008)
01-13-2011 09:30 AM
silver01cltypes
Fourth Generation TL (2009-2014)
08-12-2010 03:47 PM
idkjai
08-12-2009 11:16 PM
Quick Reply: 2012 transmission fluid filter
