2012 Acura TSX will not start
Old 06-20-2017, 11:19 AM
msv
msv's Avatar
2012 Acura TSX will not start. Car was driven fine, parked and returned after 45 minutes, the car will not start. All lights come on, no clicking. Battery was jumped radio works, dash lights up still car will not start. Battery is not the issue. Any one else experience this?
Old 06-20-2017, 11:26 AM
Received 16,260 Likes on 11,971 Posts
starter or battery.
msv (06-20-2017)
Old 06-20-2017, 11:41 AM
RTM
RTM's Avatar
Have you actually had someone test the battery with a load tester? Not just a DVM?
Old 06-20-2017, 02:21 PM
BROlando's Avatar
Received 1,163 Likes on 874 Posts
It *sounds* like an internally failed starter.
Is the ca in neutral or park?
is it manual or auto?
is there an alarm?
justnspace (06-20-2017)
Old 06-20-2017, 03:55 PM
fbt
fbt's Avatar
Does it crank over?
Old 06-20-2017, 09:53 PM
msv
msv's Avatar
Car is in park
Auto
Old 06-20-2017, 10:17 PM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Lights come on but no clicking could still be really weak battery or poor cable connection. Or the "no clicking" could be the starter solenoid gone out.
Check battery cables (pull/clean/replace/tighten).
Tap the starter with a screwdriver or hammer or something to see if you can get the solenoid to engage.
Old 06-21-2017, 09:15 AM
JDMaccord3.5's Avatar
While cranking the car (turning to start), if the dash/lights don't dim or flicker at all... then you can be sure it is the starter.
It happened to me about 4 years ago
