2011 tsx wagon lowering questions
5th Gear
Ok so after two days of reading i still have a few questions before i order my lowering springs. First off I have decided that coil overs are just out of my budget for now so I'm thinking of the 1 inch drop eibachs unless anyone has a better recommendation.Does anyone have the correct part number for the wagon springs. Also do i need anything else for the alignment like adj ball joints or camber kits. One last question is there a difference on any of the window air deflectors that go above each window.
littlett (06-22-2014)
5th Gear
Yeah chrome is a bi-product for me I have pearl white wagon going for that white on dark tint look might cover chrome trim in the brushed aluminum vinyl
VTEC just kicked in, yo!
IMO rear camber kit won't be necessary on Eibachs. They have the least amount of drop of the 3 (Eibach, H&R, TEIN S-Tech), so the rear camber won't be affected much. I haven't bothered with a rear camber kit yet, as I've read that toe is the main concern for tire wear, and not so much negative camber. If it's the looks that bothers you, a rear camber kit will be necessary.
Rob is definitely on point about the stock shocks. They will prematurely give out when used with lowering springs, so beware. But again, with a very mild drop from something like the Eibachs, this may or may not happen to you.
Onto (one of) the initial question, call the manufacturer for part numbers if you're still unsure.
I'm not sure Eibach has specific wagon springs, but I'm using sedan Eibach Pro Kits - PN 4077.140. Rear camber is impacted significantly, relative to stock but its not crazy, if that bothers you. Mine is at -3 on both sides, fronts are around -1. I got the toe fixed and tire wear is not an issue.
I'm thinking of putting a smoke vinyl over the chrome trim and the 2011+ rear chrome bar. The chrome isn't so bad on a white car, but I can do with much less of it.
Graphite Ghost
i paid 140 for 4 used handles on car-part.com
then savclaude painted them for me. it was reasonable there are 8 pieces. and sav knows what he is doing....this is what he does for a living too.
kk has an easy way to swap them....literally 1 hour for the first one while you figure it all out......20-30 minutes each for the rest and that includes time to remove the door panel.
then i sold my door handles for 140/
5th Gear
So i would think negative camber would wear inside of tires is this not true. what is the acceptable range for camber. Also puppetmaster did you need to buy after market kit to fix toe or was there enough adjustment to correct with factory equipment
I call dibs if the price is right! Oh, and of course if they colour match perfectly or not Any pics of them installed?
I'm dropped on TEIN Street Basis coilovers with about 1/2 finger gap on 18x9.5 +45 wheels. I'd say my drop is far from mild. I got my alignment done a couple of weeks ago, and they corrected the toe to 0 for fronts I think and 0.1 for rears. No camber kit. Camber on the other hand cannot be corrected much for the rear. I don't remember my settings but they weren't much different after alignment.
Here are notes from my install, along with some camber specs.
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/notes-koni-eibach-diy-install-890160/
Finally, one thing I forgot is that if you are using stock struts and Eibachs, the rear will likely be lower because of the weight. I am using Koni Sports/Yellows that have two spring perch positions and using the lower position on the front (additional .5" of lowering approx) and upper position in the rear, and only then is it an even drop.
littlett (06-26-2014)
There's also this thread with some info for wagons:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/tsx-wagon-suspension-resources-links-pictures-etc-882217/
DiamondJoeQuimby
09-10-2015 11:40 AM
