2010 TSX AC seems to be disconnected - HELP
Had my window replaced and now AC didn't work. That entire control on the car doesn't even light up. The temperature on my dash now reads "---" where the temp normally is. Also my rear defogger isn't working at all. It all started when I replaced the window. Is it a fuse issue? Please help 🤔🙂
OK - I don't have the diagrams at hand this week, but you may want to check whether the driver's window control unit is properly plugged. There are a bunch of electronics in it that communicate with other control units - Which may trigger your symptoms.
Thank you. Isn't it just one plug, just controls a lot?
OK - Looks like there is something wrong with the Multiplex Integrated Control System.
Since the issue popped up after the driver's window replacement, I would start by taking the door panel out and check all connectors. Otherwise, a trip to the dealer may be required so that they can diagnose it (read any codes that may have been set, etc.)
TLJVN
02-14-2014 05:39 PM
collegeguy60
11-06-2012 01:34 AM
