09 TSX engine
Old 09-26-2008, 03:27 PM
Too much chrome
elezam's Avatar
09 TSX engine
Does the new TSX share the same engine as the honda accord, or any other car?
Old 09-26-2008, 06:04 PM
thunderbt3's Avatar
Pretty much same K24 engine thats in the CRV, Accord, and Element. The TSX engine gets a higher compression ratio tho so theres a boost of power but you must use premium fuel. VTEC switch point is also at 5K rpm instead of 6K rpm in the 1st gen TSX
Old 09-26-2008, 06:09 PM
thunderbt3's Avatar
http://en.wikipedia.org/wiki/Honda_K_engine#K24
Old 09-27-2008, 06:52 PM
Too much chrome
elezam's Avatar
So with regular fuel you would be fine?
Old 09-27-2008, 07:16 PM
Colin's Avatar
Received 1,012 Likes on 567 Posts
The TSX uses 'true' VTEC on both intake and exhaust valves. This means you'll see three cam lobes over each cylinder on both sides. Accords and other K24s only have VTEC on the intake valves.
Old 09-27-2008, 10:27 PM
dlee74's Avatar
So that holds true for the 1st generation too?
Old 09-28-2008, 04:39 AM
Colin's Avatar
Yes
Old 10-17-2008, 10:06 PM
Pushing 200
evertp1's Avatar
actually the 1st gen TSX's have 3 cam lobes on both the intake and exhaust camshafts! not just the intake... VTC is just on the intake cam gear as it is with every other K series i-Vtec motor out there
Old 10-18-2008, 09:42 AM
soon4tsx's Avatar
The 2009 TSX, according to my Service Manual, has Variable Valve Lift and Timing only on the intake cam. The Exhaust cam is not used for VTC or VTEC.
jriv7
05-08-2020 05:50 PM
cycdaniel
12-17-2019 10:58 AM
09-14-2015 10:09 PM
ninersfgiantsfan
09-09-2015 01:14 PM
Quick Reply: 09 TSX engine
