09 TSX - 1st time posting!! Code p0339
New official member here, hoping to get some help from the experienced tsx community. I bought an A/T 2009 TSX over a year ago with 108K, which now currently has 140K. 2 months ago one morning it barely started, it gave me a code p0339 (crankshaft position sensor -intermittent). I had an apt I couldn’t miss so I took another car to be safe that day. It’s always ran fine, even with the code I continued to drive it daily w/o any issues. I assumed I needed a new crankshaft sensor, didn’t have the funds at the time to get an OEM one put in, wasn’t giving me issues (just a message at this point, the check engine light only showed up that one time) so I kind of ignored it. Now it seems like it’s finally gotten worse, drove into town tonight & I felt some very minor deceleration at about 45mph. Felt more like tiny jerks, 2 jerks in about 12 miles total, only lasted a second each, i got home fine. When i got home I shut it off & turned it back on again, it barely turned on, cut off right away. Attempted to start it again & it started right up the second time. NOW, that it is giving me problems, I started to do some research. Being that my code is NOT a sensor malfunction but rather an intermittent signal, I’m not 100% on it just being a bad sensor. After some reading online, some posts suggested that it could be something minor causing intermittent signals such as: *weak/bad starter (highly doubt, replaced less than a yr ago) *weak/bad battery *loose/corroded terminals or grounds *loose connector *break in harness In the morning I’ll run to the local parts store to get my starter/battery/alternator checked. If all that checks out, my next step would be to inspect the other stuff listed above. Worst case, if I can’t find another cause I will pick up the new sensor, but I read something about a relearn process that must be done if the sensor is removed/replaced... (would appreciate it if anyone could possibly drop a link on the relearn process or give me an idea of where to look?) So before I complicate things or start throwing $ at it Any of you guys had the same code/symptoms? Found a solution or got any tips? It’s my first post so bear with me Appreciate any & all feedback, here’s some pictures 🙂 https://cimg4.ibsrv.net/gimg/acurazi...0a0b8db1a.jpeg https://cimg5.ibsrv.net/gimg/acurazi...99c8cd980.jpeg |
1 Attachment(s)
An intermittent problem is difficult. Electrical fault could be sensor, connectors, wiring, or PCM. Unless you DIY, the lowest cost path is 1) replace sensor and 2) get help w/ diagnostics if sensor is not the problem. See DTC P0339 diagnostic attached.
good luck |
Any luck finding the issue. I'm having the same issue
Some possible causes for DTC P0339:
Low battery. If the engine is cranked with a low battery, the ECM/PCM may incorrectly judge the crankshaft sensor position. Have the battery tested and replace it, if needed. Aftermarket starter Aftermarket crank position sensor |
Code # po 339 - I had same code come up.... turned out to be the battery
Originally Posted by Mrthree1zero
(Post 16423000)
replaced it and all good now |
My 09 TSX began giving P0339 errors intermittently shortly after changing the starter with an aftermarket brand. New OEM starter did the trick.
