Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion
Old 09-04-2012, 10:57 PM
  #521
thunderbt3's Avatar
Got mine in tonight. I went with the 5000K pure white. They're so bright! I ended up setting the brightness on the 2 map and dome light to 25%. Install took about 45 mins. I was being careful not to scratch stuff up.
Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion-hxfb1.jpg
Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion-azu6k.jpg
Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion-oac6d.jpg
Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion-diyfq.jpg
Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion-ctdjm.jpg
Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion-jvqtt.jpg
Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion-vy05f.jpg
Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion-lsl4u.jpg
Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion-oxqip.jpg
Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion-gc55g.jpg
Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion-nfeko.jpg
Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion-bhxxn.jpg
Old 09-05-2012, 12:38 AM
  #522
MC MiYoung3269's Avatar
Received 1,000 Likes on 712 Posts
Those look great! Wish I could've joined in on the group buy
Old 09-05-2012, 07:49 AM
  #523
Mryank9's Avatar
Thunder, they look great! Started putting mine in last night, but didnt finish the doors because it started to rain...what year is your TSX? Just wondering bc I've heard the license plate ones install differently for the 09-10 and the 11-12..still gotta do mine
Old 09-05-2012, 08:05 AM
  #524
ROTAREDOM
ssjoeboe9's Avatar
Received 1,488 Likes on 1,058 Posts
So I went to install LED's in my doors and messed up and now the plug fell in my door. Both front doors. Anyone know how to get it out without taking the whole door apart?
Old 09-05-2012, 08:08 AM
  #525
thunderbt3's Avatar
I have a 2009. All I did was pop 3 bitch clips off of the trim of the interior trunk lid and I was able to reach inside and pop the lights off. I'll have to get setup my tripod and get some good night shots sometime.
Old 09-05-2012, 08:09 AM
  #526
thunderbt3's Avatar
Did you try to twist the lights out instead of pulling straight out or did you try to push the LED in too hard?
Old 09-05-2012, 08:39 AM
  #527
7# werC 2uoYeeS
mrstak's Avatar
the only difference is in the 2009 and 2010, you can pop open the black liner right under the lights and change them that way whereas on the 2011 and 2012's you can't because we have that chrome piece. if we try to pop out the chrome piece, we'll likely break it or scratch it so its better to get to the license plate lights from inside the trunk. pop open the clips, pull out the trunk liner and you have access to the entire license plate light housings which you squeeze from the sides to pop out and then do your business. i hope that wasn't too confusing...
Old 09-05-2012, 09:21 AM
  #528
genilladelph's Avatar
This looks damn good... Anyone do any LED conversion on the SE? I gotta take another look at it tonight.. I know the floor wells are red and there is a red ambient light that shines over the center console (which is only really relevant when doors are closed)..
Gotta figure out what combo would look best.. I like the red foot wells...
EDIT: The white LED + the red foot wells should look fine.. the red foot wells are pretty dim though I think it might look better to brighten them up a bit.
Old 09-05-2012, 09:40 AM
  #529
ROTAREDOM
ssjoeboe9's Avatar
The bulb was hard to get out, I felt like I was going to break it in between my thumb and finger so I tried to twist the plastic part and get more leverage and it just fell in the door haha. And I did it twice lol. Whats the best way to get it out?
Old 09-05-2012, 09:49 AM
  #530
thunderbt3's Avatar
The foot well lights aren't easily replaceable. The overhead accent light and footwell lights on non-SE's are blue. The exLED kit consists of 4 vanity mirror lights, 2 front map lights, 4 door lights, 1 dome light, 1 trunk light, and 2 license plate lights. exLED will also allow you to customize the colors of the lights on their website so you can mix and match colors.
http://www.exledusa.com/exled-acura-...light-kit.html
Old 09-05-2012, 09:52 AM
  #531
thunderbt3's Avatar
The light is a plug style light, it's either push or pull for the other 2 doors lol. I think the same thing happened to someone else in this thread and they were able to fix it.
Old 09-05-2012, 09:53 AM
  #532
Thanks for the info .. I'll probably just go with all white as you have done. I've read about the footwell lights and I know it's not a plug and play type deal.. we'll see...
Old 09-05-2012, 09:57 AM
  #533
Hey should have asked this earlier.. is setting the brightness pretty straightforward and documented in the kit?
Old 09-05-2012, 10:07 AM
  #534
thunderbt3's Avatar
There is no documentation, you just get nicely packaged LED lights. Brightness adjustment is just a variable resistor with a Phillips head adjustment. 0% to 100% is 1 full rotation of the resistor. I set it as low as it would go and gave it a 1/4 turn brighter. You can see the resistor on the right side of the board in the vid. Front map lights have the same adjustment on both.
I got the 5000K kit which is pure white, 6000K has a hint of blue. 5000K matches the HID's pretty well.
Old 09-05-2012, 10:30 AM
  #535
ROTAREDOM
ssjoeboe9's Avatar
Haha I know how it works lol I just wanna get my plug out of the door. I need some advice. I looked at removing the door panel but it's like 50,000 clips and screws
Old 09-05-2012, 11:07 AM
  #536
7# werC 2uoYeeS
mrstak's Avatar
joe i'm not sure what u mean by the plug fell into the door...?
Old 09-05-2012, 11:15 AM
  #537
thunderbt3's Avatar
If you twist the socket 90 deg. It can fall through the hole, into the door.
Old 09-05-2012, 12:08 PM
  #538
ROTAREDOM
ssjoeboe9's Avatar
Yes what he said lol. The first one was an accident, my friend was lookin at the bulb to see if he had the right size to give me and the second one I messed it up lol. now they are both chillin' in there "bulb caves" I thought about just giving up and trying to stick the led in place with it still in the door but it's nearly impossible. I got both bulbs out of the socket but now the plug is in the door. It's been like that for almost a year now lol
Old 09-08-2012, 12:37 AM
  #539
imKing's Avatar
How did you dim the dome and map lights to 25%?? Mine are bright as f*ck and I wish I could some how dim them.
Old 09-08-2012, 09:08 AM
  #540
The lil screw next to the "BRT" controls the brightness. Just turn it with a screwdriver
Old 09-08-2012, 10:47 AM
  #541
ROTAREDOM
ssjoeboe9's Avatar
no one knows how to get the light out of the cave in the door?
Old 09-13-2012, 08:28 PM
  #542
flex86442's Avatar
Talking
Take the door panel off...
Old 09-14-2012, 12:51 PM
  #543
BobbyC's Avatar
that happened to me a few days ago.
i used some tweezers and shoved a few fingers behind the panel and dug around til i got it back in the hinge.
it was a PITA
good luck
Old 09-14-2012, 01:44 PM
  #544
ROTAREDOM
ssjoeboe9's Avatar
uhggggg so annoying... I felt like I was warping the plastic by trying to get my fingers under there.
Old 09-14-2012, 02:35 PM
  #545
7# werC 2uoYeeS
mrstak's Avatar
think of the plastic as your girlfriend. problem solved.
The following 2 users liked this post by mrstak:
MC MiYoung3269 (09-14-2012), opboarding (09-14-2012)
Old 09-14-2012, 02:58 PM
  #546
Everyday I'm rofling
opboarding's Avatar
Received 1,788 Likes on 1,103 Posts
You can do it joe I believe in you! Just shove your fingers in farther!
Old 09-14-2012, 10:34 PM
  #547
Has anyone looked into changing the orange LED that's in the glove box?
Old 09-14-2012, 11:41 PM
  #548
7# werC 2uoYeeS
mrstak's Avatar
simon, that's a soldered led also i believe.
  #549
7# werC 2uoYeeS
mrstak's Avatar
err actually i'm not so sure anymore...might be a bulb but there's no easy way to get to it.
Old 09-14-2012, 11:50 PM
  #550
Yeah, I thought that if you twist the housing it would pop out or something but it was as stiff as a boner. Gonna dig into this a bit more since a white LED in there would be pretty sick lol
Old 09-15-2012, 12:02 AM
  #551
Hmmm, it's sold as an assembly of it's own so I'll just assume it's possible(Then again, any thing's possible LOL). Gonna take out the glove box when I have time to see how to get this lil thing out and what it looks like.... Couldn't find any pics of it other than these parts diagrams :\
Old 09-15-2012, 10:08 AM
  #552
ROTAREDOM
ssjoeboe9's Avatar
Wow real mature folks... No one can say finger without going sexual. Next I won't be able to say fist either
MC MiYoung3269 (09-15-2012)
Old 09-15-2012, 01:15 PM
  #553
Old 10-01-2012, 07:32 PM
  #554
JTRADAR61's Avatar
Anyone that has bought and installed ex led kit for tsx is the license plate LEDs light out put adjustable ? If not are the LEDs too bright ? Or just right?
Old 10-05-2012, 04:00 PM
  #555
Self Aware
fceeviper's Avatar
Originally Posted by Wired
I replaced all of my interior lights & license plate bulbs with these:
http://store.ijdmtoy.com/Acura-TSX-D...ura_df_01c.htm
I have a 2012 TSX in Bellanova White with the parchment leather interior & when these LED's light up at night they look amazing. It makes the interior look white & looks very classy. I had trouble replacing one of the bulbs for the driver side courtesy door light. The bulb wouldn't pull out & as I kept fiddling with it the housing fell right through the door. I had to use tweezers to pull it back through which took some time. Otherwise it was a very easy installation.
I just purchased these, I give them a whirl. Thx for the heads up.
Old 10-05-2012, 04:26 PM
  #556
Graphite Ghost
robpp's Avatar
the plate ones are NOT adjustable.
but they are not TOO bright. the temp is nice.......i think about 6K/
MC MiYoung3269 (10-05-2012)
Old 10-05-2012, 04:44 PM
  #557
Lol PSP
robpp (10-05-2012)
Old 10-05-2012, 04:48 PM
  #558
Graphite Ghost
robpp's Avatar
i got the plate in 07.......it was already OLD then LOL/
Old 10-11-2012, 02:56 PM
  #559
8th Gear
wlin2490's Avatar
i just placed my order for interior lights yesterday. the wait for them to come in is killing me. I did the same except for the doors i had blue. thought it would attract girls more haha
Old 10-19-2012, 07:59 PM
  #560
MrTee12's Avatar
Installed mine a couple of months ago. I love the blue. It complements the car very well.
Quick Reply: Interior lights (door, dome, vanity, etc) & license plate lights -> LED conversion
