2022 Acura TLX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2022 Acura TLX Technical Service Bulletins:
TSB 21-030 - 2022 TLX: TQI Information
Applies To: 2022 TLX (2WD, SH-AWD) - Base, Technology Package, A-Spec, Type-S, Advance Package
http://www.urvi.net/forumfiles/SB/B21-030.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-030.PDF
TSB 21-031 - 2022 TLX: TQI of the Navigation System
Applies To: 2022 TLX - ALL with Navigation
http://www.urvi.net/forumfiles/SB/B21-031.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-031.PDF
TSB 21-007 - MIL Is ON with DTC P0455
Applies To: 2021 TLX - ALL - ALL
2022 TLX - 2WD - From VIN 19UUB5...NA000001 thru 19UUB5...NA004268
2022 TLX - SH-AWD - From VIN 19UUB6...NA000001 thru 19UUB6...NA002548
2022 TLX - SH-AWD Type S - From VIN 19UUB7...NA000001 thru 19UUB7...NA001734
http://www.urvi.net/forumfiles/SB/B21-007.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-007.PDF
TSB 22-002 - Front Brake Squeal When Applied at Low Speeds
Applies To: 2021 TLX 2.0L only - ALL - ALL
2022 TLX 2.0L only - Base 2WD - From VIN 19UUB5...NA000001 thru 19UUB5...NA002135
2022 TLX 2.0L only - Tech 2WD - From VIN 19UUB5...NA000001 thru 19UUB5...NA001605
2022 TLX 2.0L only - Tech Advance 2WD - From VIN 19UUB5...NA000001 thru 19UUB5...NA001549
2022 TLX 2.0L only - Base AWD - From VIN 19UUB6...NA000001 thru 19UUB6...NA001569
2022 TLX 2.0L only - Tech AWD - From VIN 19UUB6...NA000001 thru 19UUB6...NA001231
2022 TLX 2.0L only - Advance AWD - From VIN 19UUB6...NA000001 thru 19UUB6...NA001203
2022 TLX 2.0L only - Tech Advance AWD - From VIN 19UUB6...NA000001 thru 19UUB6...NA000959
http://www.urvi.net/forumfiles/SB/B22-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-002.PDF
http://techinfo.honda.com/rjanisis/p...2-002 Ver3.PDF (Link works, but is wrong) Version 3
TSB 22-007 - Emissions Recall: 2021-22 TLX Type S PGM-FI Software Update
Applies To: 2021-22 TLX - Type S - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B22-007.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-007.PDF
TSB 22-026 - Safety Recall: 2022 TLX Bridgestone Tire Inspection
Applies To: 2022 TLX - Base - Check the iN VIN Status for Eligibility
http://www.urvi.net/forumfiles/SB/B22-026.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-026.PDF
TSB 23-010 - Software Update DTC P0300, P0301, P0302, P0303, P0304, or P0172
Applies To: 2021-2023 TLX - ALL (Except Type S) - ALL
http://www.urvi.net/forumfiles/SB/B23-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-010.PDF
TSB 23-030 - 2021–23 TLX Popping/Crackling from the Speakers; Display Blank
This bulletin has been replaced by 24-046 Warranty Extension: 2021–23 TLX Popping/Crackling from the Speakers; Display Blank, dated July 30, 2024. This service bulletin will expire August 29, 2024.
http://www.urvi.net/forumfiles/SB/B23-030.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-030.PDF
TSB 24-046 - Warranty Extension: 2021–23 TLX Popping/Crackling from the Speakers; Display Blank
Applies To: 2021-23 TLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B24-046.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-046.PDF
Last edited by EE4Life; 07-30-2024 at 11:31 AM. Reason: TSB 23-030 was revised. Added TSB 24-046
Jim2301 (06-21-2022)
