Why are the front and rear brake disk worn differently?
Old 05-09-2002, 12:34 PM
I have put 400 miles on my new TL and I visually checked the brake disks through the wheels. I found that the two front brake disks were worn very well and looks like mirrors. But the two rear brake disks are less smooth. Is this normal?
Old 05-09-2002, 12:36 PM
aepiua's Avatar
Yes, more weight on the front. You will typically replace your front brake pads twice for every one time you replace the rear.
Old 05-09-2002, 01:40 PM
and the way the braking distribution is set up, the front actually does around 65% (?) of the braking.
Old 05-09-2002, 03:48 PM
The front brakes do a majority of the braking, probably around 70% or so...that's why they wear out faster.
Old 05-09-2002, 04:36 PM
I've seen BMWs and Audis with normal wear on both front and rear disks. So why would our TLs be any different?
Old 05-10-2002, 08:22 PM
ChucksCL-S's Avatar
Retiree, our cars are not different. You have only gone 400 miles. I have 107,000 miles on my 2000 TL (salesrep) and I've replaced both front rotors once and the rears will probably go 250,000 miles which is normal. The fronts do 80% of the work! If braking force was proportioned 50/50 front &rear your rear tires would skid every time you braked much more than gently.
Old 05-10-2002, 09:18 PM
I meant the front disk are evenly worned while the rear ones have deep grooves inthem. Is it really normal ??? should they not also be worned evenly ?
Old 05-10-2002, 10:27 PM
retiree:
I also see grooves on my rear disks while the fronts are like mirror. So I guess it should be normal.
02-25-2020 09:57 AM
mav888
1G RDX (2007-2012)
09-08-2015 11:49 AM
nishant11
09-02-2015 10:34 AM
Quick Reply: Why are the front and rear brake disk worn differently?
