Notices
Where is 2nd gen Wiper Relay located????
Old 09-17-2009, 11:56 AM
Registered Member
3.2VtecTL's Avatar
Exclamation Where is 2nd gen Wiper Relay located????
i've looked on the main fuse box under the hood and it isn't located there....
there are also two relay boxes in the engine bay with 3 to 4 relays....could one of those be it?
if so which one? if there is a diagram or anyone has a service manual could you please post a picture of it....i've searched extensively!
3.2VtecTL is offline
Old 09-10-2018, 10:30 PM
New Member
I'm having same problem I think. Wipers won't shut off unless I turn car off then back on. I can press lever down to turn them on and when I let off lever they shut off. Can someone please just take a picture of where the wiper relay is and post it?
David Spencer is offline
Old 09-11-2018, 07:56 AM
Registered Member
The relay is on the firewall near the brake booster.
Saudade is offline
Old 09-11-2018, 09:33 AM
Registered Member
Iggy's Avatar
Iggy is offline
Saudade (09-11-2018)
Old 09-11-2018, 10:37 AM
New Member
Thanks so much. Much appreciated
Old 10-17-2018, 11:27 AM
Registered Member
Question
Originally Posted by Iggy View Post
Thanks so much for posting this picture/the location. I tried to remove/unplug the wiper relay for about a half hour and it seemed impossible. I even unbolted that rusty metal bracket (pictured) that's holding it, hoping to get better access. From feel, it seems that there's a clip to release on the relay, but neither my hand nor a screwdriver could fit back there to release it.
Is there some sort of trick to disconnecting/removing it?
ArmchairArchitect is offline
Old 10-17-2018, 12:13 PM
Registered Member
Iggy's Avatar
No clip. The relay just lifts out. You'll need to wiggle it back and forth while pulling up.
Iggy is offline
Old 10-17-2018, 01:00 PM
Registered Member
Thanks- I must have wiggled, pulled, and twisted that thing for a solid half hour and it wouldn't budge from the lower wiring harness attached to it.
Old 10-17-2018, 08:38 PM
Registered Member
Iggy's Avatar
My apologies man, I was thinking of other relays in the box next to it. The wiper relay looks like it may have a locking tab on the bottom that needs to be squeezed to release it.
Iggy is offline
Old 02-14-2019, 10:29 PM
New Member
Did anyone figure this out? I have the same problem, wipers wouldn't turn off. After driving it for a couple hours they WILL turn off but Intermittent wiping keeps stopping for a few seconds, midway, stopping for a few seconds again, etc.
LegendGirl is offline
Old 02-19-2019, 07:59 AM
New Member
I am having the same problem. I can't seem to get the relay out to replace it.
damoss is offline
Jamus22
08-25-2018 01:53 PM
Kres43
First Generation RDX (2007-2012)
10-03-2015 07:16 PM
Acura604
Third Generation TL (2004-2008)
09-28-2015 12:24 PM
Quick Reply: Where is 2nd gen Wiper Relay located????
