vibration at 40 mph and over on acceleration
hey guys, i have been having an issue with vibrations going 40 mph or over on acceleration on the front passenger side for that past 8 months. some things i have done to remedy the situation is rotating and balancing the tires (tires have been balanced 3 times now), changed the axles 4 times now (newest axle is oem), and have replaced the front and passenger side motor mounts i have taken it to two different shops to see if they see anything and both shops have nothing for me. if anyone has any ideas, it would be greatly appreciated.
Wheel bearings? Ball joints? Steering column? Alignment? A vibration could be coming from a variety of places. I would seriously recommend you take it somewhere else and get another set of eyes on it.
Yeah, if balancing tires and replacing axles hasn't resolved your vibration issue.....then ya need to have an alignment shop evaluate the suspension and steering components, IMO.
Could be a bad rim or tire, maybe a BJ,WB,tie rod end, brake rotor or strut ??? Duhh !!!
Did you try both axles, or only the passenger side? I have not found a reliable way to differentiate. If you haven't, replace the driver side. Use new, not reman; it doesn't have to be oe.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
