Notices
Valve Adjustment DIY in progress
Old 01-09-2011, 10:32 PM
  #161
Registered Member
Received 1,107 Likes on 1,039 Posts
Please buy a GO- NO GO feeler guage!!!!!
it will make your life simple when doing valve adjustments
stick it in- it stops and is correct or it keeps going means too loose
wont go in at all- too tight!
I imagine IHC, fries, and the other real techs will agree- its the right tool for the job,
and not many dollars at parts store- maybe harbor freight too,
or buy a great one for many years of use, matco or snap-on off the tool truck!
I learned on the `guess the drag` type (still have 3 sets of them in the toolbox), and then bought the right thing- (only needed 1 of it)
made all valve adjust services easy,,this was back doing 5-15 valve adjustments a week on datsun/nissanZ cars, plus those pita bimmers
No valves to adjust on RX7 rotary~~ my favorite car in for a major service!!
01tl4tl is offline
Old 01-09-2011, 10:34 PM
  #162
Registered Member
the fuel injectors make a lot of noise,, once the valves are adjusted
nothing you can do about it
and the purge thing clicks as said before
01tl4tl is offline
Old 01-10-2011, 09:31 AM
  #163
I got the Shifts
phee's Avatar
U should not lift the rocker. It will cause all your valves to be over tight
phee is offline
Old 01-10-2011, 10:52 AM
  #164
Registered Member
Received 1,780 Likes on 1,260 Posts
Agreed on the go/no go feeler. It's quicker and especially for the first timer it takes some of the guess work or "feeling" out of it. I've done probably 5-6 valve adjustments and it's normal for me to have to go back once or twice after the adjustments until I get the feel of it if I don't have a go/no go gauge.
I hate cars is offline
Old 01-10-2011, 02:03 PM
  #165
6spd
Jaeson's Avatar
I just got the go no go feeler gauge. But I'm getting 2 different answers about lifting the rocker.... If you don't lift it, you're basically saying there's extra play in the rocker/valve in addition to the clearance you just measured. That doesn't seem right. I already tried that, and it seems the valves are too loose (although maybe I didn't measure it with enough drag).
Jaeson is offline
Old 01-10-2011, 02:05 PM
  #166
Registered Member
Lifting it is fine. You're pushing it against the cam which is what you want to do to take all the slack out. Gravity should not come into play.
Old 01-10-2011, 02:23 PM
  #167
2003 TL-p
gold2003tl (90)'s Avatar
^ exactly what i did and though was correct. all i used was a little common scene and a set of angle bent feeler gauges. i simply tripled checked everything making sure larger sized gauges wouldn't fit and smaller sized gauges be loose with play, and the correct sized gauge having light drag with no play. you really cant mess it up if you really think about whats going on, just make sure that gap when the rocker is lifted is the same thickness of the gauge.
iv learned to use regular straight feeler gauges on small 4 stroke engines so thats my practice. my car wasn't much harder, just a much bigger job.
gold2003tl (90) is offline
Old 01-13-2011, 03:02 AM
  #168
6spd
Jaeson's Avatar
Thanks for the tips guys. After some drama (battery died), I got the car started and no more TICKING! I used both feeler gauges and was very detailed about it this time. I guess I shouldn't have done it outside in the cold in the dark the first time around because I was just rushing to get it done so I wouldn't get a frostbite.
Here's a video
http://www.youtube.com/watch?v=blbSfhNNidc
Jaeson is offline
Old 01-13-2011, 01:59 PM
  #169
2003 TL-p
Old 01-16-2011, 05:55 PM
  #170
6spd
Jaeson's Avatar
LOL more drama. I've been driving around for the past few days, and the car runs fine, feels stronger than before, no ticking. Today, accelerating at around 45mph, my CEL started blinking a few times and then went away. It didn't feel anything different, and the car seemed to run normal. I went to Autozone and it said P1399 - random misfire. I'm not sure what to do now.... car seems to run fine but I don't wanna risk anything.
Any ideas? I might try Seafoming it...
Jaeson is offline
Old 01-16-2011, 06:01 PM
  #171
Registered Member
You got some too tight. No big deal, go back and redo. Just don't take too long because you will burn the exhaust valves if they don't fully close and seat well to transfer heat to the seat. It doesn't take long to hurt them.
Don't Seafoam. It's worthless and has the potential to cause more problems. If you pulled any spark plugs out, check connections on the coils first and gaps when you pulled them out. I've hit the plug on the way in to the hold and closed the gap down to nearly zero and cause a misfire.
Old 01-16-2011, 07:01 PM
  #172
6spd
Jaeson's Avatar
You sure it's not something else? It's weird that it only happened once and went away in 4 days of driving around 50 miles. Maybe it's one of the gaskets? Man, it's gonna suck doing this a third time. How many miles you reckon I could drive like this? I don't have time until next weekend....
Oh and I didn't pull the spark plugs out, just the coil packs.
Jaeson is offline
Old 01-16-2011, 07:10 PM
  #173
Registered Member
Start with the easy stuff such as the coils. Make sure the plug holes are not filled with oil. After all of the easy checks are done and you don't find anything it's time to recheck the valves.
More than likely a coil issue would throw a specific cylinder misfire code, not a random misfire but it's always possible.
Old 01-17-2011, 07:44 PM
  #174
6spd
Jaeson's Avatar
I def think it's not the coilpack, because I've had one of them go bad before and I could feel it. I'll check and make sure the gasket isn't on backwards or something...
Jaeson is offline
Old 04-08-2011, 12:46 AM
  #175
01 Type-S, Sexy Silver
disgruntlednut's Avatar
So I'm planning on doing this Saturday morning. Almost 170K miles so it's way overdue. Need to clean out that EGR while I'm at it. Ordered the Outlaw Engineering ThermoBlok kit:
"Includes intake manifold spacer, throttle body spacer, gaskets, installation kit, bypass fitting, detailed instructions and OUTLAW ENGINEERING decals!" (I'm really excited about the decals, that's the main reason I ordered it.)
Am I going to need any additional gaskets or anything?
disgruntlednut is offline
Old 04-08-2011, 08:03 AM
  #176
I got the Shifts
phee's Avatar
Jaeson they aretoo tight. U shouldn't have lifted the valves to tighten them all the way. There is nothing in the manual that states that.
phee is offline
Old 04-08-2011, 10:47 AM
  #177
2003 TL-p
what do you mean by that?
its required to lift the rocker arm up to insert the feeler gauge, and then you adjust and tighten the lock nut and recheck clearance again with the feeler gauge after tightening. unless im missing something here?
Old 04-08-2011, 10:51 AM
  #178
Registered Member
the outlaw kit has everything you need for the install- no extra gaskets or parts beside the 3 cans carb cleaner for the egr cleaning- get non chlorine stuff -its safer
Doesnt hurt to remove the plenums on edges of manifold and clean in there too- get everything you can while its apart
where it says to use vise grips to remove 2 studs that get replaced with longer ones,-dont!
that can let shards of metal come off the stud if tool slips ~ bad news
Instead, use 2 nuts locked against each other on the stud- then you can turn by the lower nut and it comes right out = no danger
reminder- in 500 miles go back and retorque all the manifold bolts- they tend to loosen slightly with heat cycles
01tl4tl is offline
Old 04-08-2011, 10:55 AM
  #179
Registered Member
re: lifting valves to adjust
your feeler guage should slide in with little drag, or if it wont go- the valve is tight - try next thinner size to see how much
dont lift anything from its resting position, or the next thing goes out of whack
I hate cars doesnt like seafoam- ok- bg makes good stuff too
properly used its no prob at all and carbon buildup- especially with E10 gas- is a real issue
gas makers wouldnt add nitrogen (shell) or other boosters that claim to clean intake valve backs and pistons of carbon,,unless the crud their gas creates is real
01tl4tl is offline
Old 04-08-2011, 11:33 AM
  #180
I got the Shifts
phee's Avatar
exactly.
phee is offline
Old 04-08-2011, 07:40 PM
  #181
The plan for tomorrow is:
Clean K&N Filter
Clean EGR port
Clean TB and whatever I can in the Intake Manifold.
Install ThermoBlok IM Gaskets and TB Spacer
Replace PCV valve
Adjust valves
TB Coolant Bypass
(Maybe replace spark plugs)
Moderate mechanical experience (anything from changing a bulb to a full timing belt job), but haven't ever really tried tackling more than that.
Besides what's been posted throughout this thread, any comments, concerns? Advice encouraged.
Old 04-08-2011, 08:08 PM
  #182
More notably: Anything else I should do/check/fix/look for while I've got everything torn apart?
Old 04-08-2011, 11:37 PM
  #183
Registered Member
mostly,,clean the egr passageway thru the manifold with a wire coat hanger (after soaking with carb cleaner)- not just the ports under egr valve and the other end, rinse manifold well and totally dry!!
See diys and read instructions supplied with parts
Make sure the top most gasket as you remove the engine covers- stays UP side UP--dont flip over or it will bite you if installed that way--fits but wrong~
I wouldnt bypass the coolant/(actually `heater line`) to TB, its needed in certain conditions to prevent icing in the system
and doesnt rob too much performance --unless you are going to race the car in auto-x or similar
01tl4tl is offline
Old 04-08-2011, 11:40 PM
  #184
Registered Member
unless they failed -no reason to replace egr valve- usually some wd on the arm gets it working like new
and the pcv- carb cleaner/deep creep will remove sludge inside it,,unless its 3 bucks or less,,
then replace it= for time savings to do other jobs
plugs if more than 70kmiles on the current ones
bg seafoam or redline never hurt to clean internals and injection system - when done correctly = following simple directions~
01tl4tl is offline
Old 04-09-2011, 01:22 PM
  #185
Is there any way to clear out the gunk that's built up in the EGR port on the motor? Got the IM side clean, now wondering about the motor side... i.e. Without dropping any of the crap inside.
Old 04-09-2011, 01:52 PM
  #186
I got the Shifts
phee's Avatar
take the manifold off and let it soak in some soapy water. take a metal hanger and pound out the hole with it
phee is offline
Old 04-09-2011, 04:25 PM
  #187
I've got the EGR port clean on the IM. But the hole that it connects with on the top of the motor is filled with the same gunk.
P.S. The rear valve cover is the biggest pain in the ass I have ever seen.
Old 04-09-2011, 05:47 PM
  #188
I got the Shifts
phee's Avatar
remove the IMRC and ubolt the power steering hose-bracket.
phee is offline
Old 04-10-2011, 12:40 AM
  #189
Thanks for the replies guys, I really appreciate it.
I managed to break a bolt while putting one of the valve covers back on. I could kick myself right now. Too tired and wasn't thinking straight.
Old 04-10-2011, 08:29 AM
  #190
I got the Shifts
phee's Avatar
Get it fixed or it will leak
phee is offline
Old 04-10-2011, 10:00 AM
  #191
It was one of the bolts on the back cover. Got the broken piece out. Gonna use a bolt from the front and put everything back together until I can get a replacement bolt tomorrow since the dealer is closed today.
Old 04-10-2011, 10:24 AM
  #192
I got the Shifts
phee's Avatar
good idea. i have a few of those bolts laying around since they love to break. plus i always break bolts
phee is offline
Old 05-08-2012, 08:53 AM
  #193
Registered Member
LECKEY73's Avatar
Are all the Numbers on the cam
Originally Posted by juanclopez2786 View Post
just in case you guys need the acura instructions on doing a valve clearance adjustment here it is!
1 Remove the cylinder head covers.
2 Remove the front upper cover .
3 Set the No. 1 piston at top dead center (TDC). Align the pointer (A) on the back cover with the No. 1 piston TDC mark (B) on the front camshaft pulley.
4 Select the correct thickness feeler gauge for the valves you're going to check.
Intake:
0.20-0.24 mm (0.008-0.009 in.)
Exhaust:
0.28-0.32 mm (0.011-0.013 in.)
5 Insert the feeler gauge (A) between the adjusting screw (B) and the end of the valve stem and slide it back and forth; you should feel a slight amount of drag.
6 If you feel too much or too little drag, loosen the locknut (A), and turn the adjusting screw (B) until the drag on the feeler gauge is correct.
7 Tighten the locknut and recheck the clearance.
Repeat the adjustment if necessary.
8 Rotate the crankshaft clockwise. Align the pointer (A) on the back cover with the No. 4 piston TDC mark (B) on the front camshaft pulley.
9 Check and, if necessary, adjust the valve clearance on No. 4 cylinder.
10 Rotate the crankshaft clockwise. Align the pointer (A) on the back cover with the No. 2 piston TDC mark (B) on the front camshaft pulley.
11 Check and, if necessary, adjust the valve clearance on No. 2 cylinder.
12 Rotate the crankshaft clockwise. Align the pointer (A) on the back cover with the No. 5 piston TDC mark (B) on the front camshaft pulley.
13 Check and, if necessary, adjust the valve clearance on No. 5 cylinder.
14 Rotate the crankshaft clockwise. Align the pointer (A) on the back cover with the No. 3 piston TDC mark (B) on the front camshaft pulley.
15 Check and, if necessary, adjust the valve clearance on No. 3 cylinder.
16 Rotate the crankshaft clockwise. Align the pointer (A) on the back cover with the No. 6 piston TDC mark (B) on the front camshaft pulley.
17 Check and, if necessary, adjust the valve clearance on No. 6 cylinder.
Are all the Numbers on the cam as shown in the pictures?
LECKEY73 is offline
Old 05-08-2012, 09:31 AM
  #194
Registered Member
LECKEY73's Avatar
Sorry
THEY SAY READING IS FUNDAMETAL
LECKEY73 is offline
Old 06-13-2012, 05:55 AM
  #195
Registered Member
I have a question...in this picture ...what anchors the coil pack sleeve at the base where the plug is?? Is there a gasket as there is at the top or something else?
Zenica is offline
Old 06-13-2012, 04:30 PM
  #196
Skirmich's Avatar
Yes there must be 3 Rubber Donuts on Each to keep the Oil out of the Spark plug Shaft...
Just in Case this is a Pic of the Valve Cover Gasket Replacement:
Notice the 3 Little Donuts those are what goes on top of the Shafts.
And To ADD to this awesome DIY I found out this tool before Hand to Adjust the Valves themself Makes the Work a Little Easier:
Amazon Amazon
Its just a Socket Wrench with an Included Flat Screwdriver that goes in there to adjust the Screw and Nut at the Same time Pretty Handy!
Skirmich is online now
Old 08-22-2012, 05:43 AM
  #197
Registered Member
Thought that I following the instructions correctly
I spent quality time to adjust the valves as described (leveraged this thread and the service manual), but it seems that something went wrong. My first 2 big trips (2+ hr trips) I found my engine oil a quart down after the trips. It seems that I may have tightened too much as my MPG has also gone down although the performance has been great.
I am open for ideas as the loss of oil stumped me a little since there is no drainage on the engine. I ask now as most of my trips are local at the moment so it is an ideal time to repair something that may be out of sync with the valve adjustment.
Thanks.
bill_talbot is offline
Old 08-22-2012, 11:19 AM
  #198
Registered Member
just for fun bill, ck the pcv valve for free movement of ball inside
been reports of those clogging and excess pressure will force oil
out thru the engine rear main seal,,there is an inspection plate under car for that leak
everything was set to torque spec on bolts?? gaskets good,,bolt gaskets good and none missing.. as seen in pic above your post?
I know we run one side of our valves at min spec and the other just a tick over mid spec
but dont recall which at the moment
too tight valve adjust is danger city!! for valve to piston contact
especially if there is carbon buildup on pistons
too tight bolts are crushing gasket seal
01tl4tl is offline
bill_talbot (08-24-2012)
Old 08-22-2012, 09:24 PM
  #199
Registered Member
I will check PCV valve tomorrow for flow. I did the specs according to the svc manual, but if that is off I am more than happy to take a look. (after adjusting them once it really isn't too bad to take a look at again).
Here are the specs the service manual provides:
Intake:
Exhaust:
I did replace the gaskets while performing the adjustment previously and tightened all to spec as the engine has 100k+ on it. ...and visually I didn't see any leaks when the oil level was found to be low.
Open for ideas as this definitely caught me off guard.
Thanks.
Old 08-24-2012, 06:36 AM
  #200
Registered Member
Ok, so I reread this entire thread with the following results:
1) confirm that PCV valve is not clogged; otherwise, spend $5 to on a new one for additional insurance
2) the adjustment specs should be:
Intake: 0.20-0.24 mm (0.008-0.009 in.) - Tighten as close to .009 as possible as it will loosen over time
Exhaust: 0.28-0.32 mm (0.011-0.013 in.) - Tighten as close to .012 as possible as it will tighten over time
3) do not lift the rockers when performing the adjustment
4) only turn crankshaft in clockwise direction
5) line up TDC between the back cover and the TDC mark on the camshaft pully (the diagrams within the service manual are not exactly perfect)
6) only perform on a cold engine
7) take your time to perform the adjustment. It is not hard, only tedious.
Please confirm that I am capturing this correctly. My goal is to do this today, if possible.
Thanks.
Quick Reply: Valve Adjustment DIY in progress
