Vacuum line identity?
Old 07-11-2008, 11:07 PM
baddbenny's Avatar
So - im gonna Seafoam this weekend - pretty stoked to see what all the rave is about. Feeling a little lost in a very simple aspect of the process...
Which line is my VACUUM LINE???
I've search, and seen only broken links to the pics I need to see...
Can anyone help, post a pic, explain well?
Thanks~
Old 07-11-2008, 11:22 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
check the diy- the first page of directions are pretty good- but show wrong port
about post #147 the correct port is shown
Rmove the 4 bolts holding the plastic engine cover on- remove the cover and place safely somewhere
You cannot miss the vac line WITH clamp on it--and the throttle assembly
If you buy 1 can 16 oz can Seafoam for the gas tank- put it in 1/2 tank
And 1 can Deep Creep- its seafoam in a paint spray can- thats way easier to use and control what happening putting it in the vac port
Look for the Seafoam threads and there is all you need to know!
Old 07-12-2008, 05:25 AM
baddbenny's Avatar
AWESOME! Perfect pics!
So I get a good dose of the FOAM in there, replace the hose?
Let it set, and then go for a heated cruise.
I plan on a whole bottle in my gas at half tank just before the pre-dose warm up run - Can I change my plugs after, that same day with my gas still foamed???
Thanks~
Old 07-12-2008, 07:19 AM
01tl4tl's Avatar
slow sips or squirts are the key- should take 10 minutes to get foam in vac port
Make sure to warm the engine with 10 minute freeway cruise before seafoam- the follow the directions of the post-drive to loosen and blow the crud out- failure to follow directions will lessen results
Wait a few days for the grunge to clear out before replacing spark plugs- give them a good clean home- not one in progress- the gas tank is still cleaning stuff as it goes thru the engine
Old 07-12-2008, 04:05 PM
baddbenny's Avatar
that line sucks with a mighty force indeed! It was loud too!
She ate it all up and things went smoothly. I posted a little write up on the experience.
Thanks 01tl4tl
MrHeeltoe
20
02-23-2023 01:54 PM
SidhuSaaB
05-30-2020 12:40 AM
copmagnet82
4G TL Problems & Fixes
06-29-2016 08:09 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Vacuum line identity?
