Turned but rumbled and turned off
Old 02-01-2006, 08:08 PM
Pimpn' Ain't Easy
GreenTL99's Avatar
I have a 99 TL 101,389 that never has had issues, but today I was in a cold parking garage and when I turned it on, it rumbled (low) and then turned off. I tried it a second time and nothing, the engine did not turn on.
A third time and I could feel it wanna start, so I gave it a little gas and it worked fine, like a champ.
Does anyone have any idea what caused this? Could it be the fuel pump?
Old 02-01-2006, 08:19 PM
05 C230K & 09 135i 6MT
03CoupeV6's Avatar
Meeehhhhhh
That could be lots of stuff, AFAIK. See if it keeps doing it and report back.
Old 02-01-2006, 08:49 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Old 02-01-2006, 09:00 PM
Flyin' and Drivin'
Comet2404's Avatar
Yes I had this issue with my 99. It sounds to me like your EGR is clogged. Your spark plugs will probably have to be replaced as well. I replaced both and my car worked flawlessly. But you cant just replace the EGR, you have to clean out the port that allows the air to flow into the valve. Acura was going to charge me an arm and a leg, so I took it to another reputable import service shop. While they are cleaning that out have them clean out your intake manifold as all sorts of nasty deposits build up there. If you have big enough balls you can do it yourself, but I apparently dont, and thus I chickened out and had someone else do it for me!
Old 02-02-2006, 01:34 AM
03CoupeV6's Avatar
EGR should throw a DTC. He didn't mention the CEL at all.
Old 02-02-2006, 07:07 AM
Flyin' and Drivin'
Comet2404's Avatar
Yeah, mine didn't come on until things started to get really bad though. It did it for about a week before the CEL came on. Strange huh?
Old 02-18-2006, 11:42 AM
8th Gear
jdsallpltnum99's Avatar
how much should you expect to pay for the egr cleaning and what not?
Old 02-18-2006, 12:00 PM
On the way!
fla-tls's Avatar
Hopefully its a simple case of bad gas.
Old 02-18-2006, 01:45 PM
2400 Watts in a TL...Why?
ResidualFreedom's Avatar
It'ssimple carbon build up... typical in the 99TL-P with around 80-100k miles.. Search for fsttyms1's DIY on cleaning it and you'll be fine.. get new spark plugs will help as well but the main problem is the air ports are clogged with carbon.. Take a sat morning, pull the top of the engine off, wash it out and aget all the carbon out, let it dry, put it back on, ...you're good to go!
Look into the DIY for specific bolts and hjoses to remove, this is not a hard DIY.. trust me, I've done a ton of things on our car with my own two hands; Headers, valve adjustment (was running the engine while looking at the lifters and rods.. this was pretty scary), spring swap, custom 3" CAI, thermo block spacer install, etc..... this wouldn't be close to the hardest thing I've done.. I'd feel confident a newbie could tackle this with a 6 pack and a saturday..
Old 02-18-2006, 05:55 PM
8th Gear
can i clean it
I've been trying to find a place that sells the acrual egr valve kit, but i only come across the whole valve! Do i HAVE to replace the whole valve? or can i just clean it out with some carb cleaner and let the intake manifold dry and slap it back on? If someone knows for sure please let me know, this light is pissin me off now thanks
Old 02-18-2006, 05:56 PM
8th Gear
can i clean it? or do i have to replace it completely?
Old 02-18-2006, 06:43 PM
Boomer SOONER
ou sig's Avatar
do exactly what others have said - clean the intake manafold and the small port that is in there and put it back and you will be fine. I did that on my '99 TL after about 85k miles and it is still fine 15k miles since. You do not have to buy a new EGR valve.
Just take off the bolts and hoses...clean it (it took me 2 cans of carbon cleaner stuff) wash it out and put it back on. Torque the bolts/nuts to 12-15 ft/lbs.
IBankMouse
06-13-2020 12:53 PM
SidhuSaaB
05-30-2020 12:40 AM
LoneRonin
01-04-2016 01:03 AM
rockyboy
09-29-2015 12:05 AM
Brandle34
09-23-2015 07:20 PM
Quick Reply: Turned but rumbled and turned off
