Transmission Fluid color turning color
Old 11-22-2004, 02:26 PM
ronrecr's Avatar
Has anyone noticed this.. after the oil jet kit was installed fluid went from pink to motor oil color in 1200 miles.on mine anywy 2000 tl 41k on it.. thanks
Old 11-22-2004, 02:30 PM
Kollage is funn!
shawn744's Avatar
well the tranny itself is acura's problem....and plus, in the manual it says to change tranny fluid every 120k.....so it's not really important. the last person who messed with it would be the dealership....but it's always nice to know why.
Old 11-22-2004, 02:38 PM
scottosan's Avatar
I was under the impression to change the tranny fluid every 30k regardless the vehicle type
Old 11-22-2004, 03:05 PM
aw1
aw1's Avatar
correct me if im wrong.. I thought the tranny fluid should always remain reddish with a little bit of brown...if it turns to the same color of motor oil, then there is a problem...
Old 11-22-2004, 03:22 PM
aclura's Avatar
Correct, reddish If it turned dark that fast the tranny is going soon, You can join the club. Mine last 50 mi. after the oil jet. We got our on thread!!
Old 11-22-2004, 04:45 PM
WiLLs TypE S's Avatar
So should I even go into acura to get the oil jet installed?
Old 11-22-2004, 05:02 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
yes the oil jet DOES NOT cause the failures. your tranny if it goes has been on its way out long before the oil jet kit. the oil jet kit DOES NOT fix the problem of it failing that 99.9% of us have had. it does keep the 2nd gear shaft from overheating and breaking (which is a completly different problem) by not getting it you would possibly be voiding the warranty offered by them by not getting it. ive had 3 failures and none of them have had teh oil jet kit. I also just finished rebuilding my "SPARE" tranny and the problems arent related to the oiljetkit.
Old 11-22-2004, 05:50 PM
ronrecr's Avatar
The manual in my 2000 said to change at 90k under regular conditions.
Old 11-22-2004, 06:03 PM
ronrecr's Avatar
The Acura tech said they would of noticed if the fluid was bad when they did the jet kit 2 months and 1200 miles ago .. it was pink and changed color that quick. I just got it back from having the brakes fixed on recall
Old 11-22-2004, 06:16 PM
Thx...but if i get a comptech headers I will void warranty either way..lol. so I'll get the jet..n then install the header =D
Old 11-22-2004, 06:39 PM
Resident Troll.
ndawood's Avatar
your comptech headers will not void the warrenty on the car. most dealers recognize headers and an intake as pretty standard these days and wont give you a hard time, if they do they are just being dicks and you shouldnt be doing business with them to being with...
either way get the oil jet installed, might as well since they are providing it, and if anything goes wrong you will have your warrenty so its nothing something to worry about too much
Old 11-22-2004, 08:37 PM
fsttyms1's Avatar
honda wants it much sooner than that now with the tranny probs
Old 11-25-2004, 05:38 AM
heehaaw's Avatar
shouldnt be the colour of motor oil. somethings screwed.
mada51589
05-03-2022 08:54 PM
cobra10363
01-16-2021 08:12 PM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
Quick Reply: Transmission Fluid color turning color
