Transmission died on my 02 tl type s, can i use this trans?
I tried searching, and i couldnt find specific enough information this.
I found a 07 accord 3.0 v6 coupe transmission w/ torque converter.
Is this all I need? so basically swap the bell housing and all the sensors, and it should be direct bolt in correct?
are the accord v6 coupe and 4 door transmissions different? please let me know asap I need to get this thing ordered.
thanks in advance
thanks in advance
that was a waste of a post...
can anyone link me to any specific swap threads, ive seen them before, but for the life of me I cannot find it.
More importantly, I need to know if the coupe and 4door transmissions are different. I'm having a shop i trust swap it out for 1200 labor, i found a trans for 1300 w/ 45k on it. i think thats a decent deal
Chapter Leader (Southeast Region)
Yes it will work I did the same thing on my car. All you will have to do is swap the range switch, entire cooler/warmer filter assembly, and third and fourth gear pressure switches. The 2 door and 4 door had the same transmission.
thanks in advance
thanks in advance
I would replace transmission mounts, third Nd fourth gear pressure switches, and the spin on filter on top. That's what I did. I have mounts and a filter that I didn't use because they didn't get here in time. Send me a pm if you need them.
Here is a link https://acurazine.com/forums/showthr...t=accord+trans
I am right in the middle of my swap also. Took the old trans out today and have a '07 accord transmission arriving tomorrow to go back in. If you need any advice taking out the transmission its fresh in my mind right now lol.
Also the service manual helps out a lot. Here is a relink for it
http://dl.dropbox.com/u/71229813/!!!...E%20MANUAL.pdf
http://dl.dropbox.com/u/71229813/!!!!!!!!ACURA%2099-03%20TL%20SERVICE%20MANUAL.pdf
Moving on, what is the spin on filter that I need to replace? I called honda they said they don't have filters for these transmissions?
There's a spin on filter that connects to te oil cooler filter assembly rift under the air intake box. You can use the the third and fourth gear pressure switches from either one.
The entire trans oil heater assy, including the plate under the heater/cooler itself, and all of the brackets *don't forget a new gasket for the plate and anew trans filter* If the old trans has an oiljet kit installed, you will have to cut the t's out of it and fasten a new hose to both ends of the intermediate line.
yea so far I found the spin on filter and trans mount at NAPA, now im still looking for the gasket for the heater/cooler assembly as well as the pressure switches. hondas got the av6 ones for 45 a piece.
^ mine needs to be replaced with 193,000 miles on the car and 90,000 miles on the second transmission that died. When I took it off the car it broke apart into prices.
Here's te part number for you. No point in taking a chance for a gasket that's less than two dollars.
25812-P7W-A01
25812-P7W-A01
alright awesome thanks guys!
ive got the gasket, filter, and mount all sourced out.
still deciding if i should replace the pressure switches, the trans has 42k on it, i can get the 2 honda ones ofr 100 or the two acura ones for 200 bucks, worth it?
You could probably use the ones that come with te new transmission. The only reason I replaced them was because one was damaged and I did it as preventative maintenance
hey guys, got the transmission in, everything seems to be shifting fine in Drive, but the D5 light is off, and it won't shift into sport mode, the sport mode gear light won't even light up, anyone have any idea whats up?
-range selector switch was swapped
-new filter, all hoses cooler/heater was swapped over
-new gasket
-harness was swapped over
-new gasket
-new gasket
-new gasket
justin7779
12-25-2015 10:33 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
