Tranny just started slipping, how long until it goes?
Yesterday i felt my tranny slippin and today it became worse. How much can I get out of it til I need a new 1?
smell the trans dipstick- if burnt fluid its got days
What type of slipping?- on throttle full and 2nd gear, or every gear doesnt want to change or gas it on freeway and it slips to 5000 rpm etc
whats your year and mileage?- salvage title or good title?
ck your VIN with acura 1-800-382-2238 x5 register as the owner and ask if any open recalls (new one for airbag) and if part of the trans extended warranty
thats 7year+9months or 109kmiles from date sold new- acura 800 can tell you that info
if it freaks out and goes into `limp mode`- 2500 rpm max-
get off the road and park- key OFF for 15 minutes to let trans cool
restart and it will usually get you home
Well it takes like 4 sec to engage into reverse...and usually its been studdering when goin into 3rd gear...like after 3sec it kicks into the gear hard
Well takes like 2-3 sec to go in reverse....i got 184k n it already was serviced a long time ago way b4 i ever bought the car....sum1 sellin 1 for 700 so maybe i'll jump on that
Take the solenoids out and clean them off, and do a single drain and fill
should be a DIY for it, or search for the thread on selenoid cleaning-- kris? link?
They are external
get 4 qts honda atf at honda dealer- should take 3.2 with a good draining
They are external
Always Working In
Couldnt find info for the 00-03 trans just the 99 but download the service manual. It has all the info you need.
http://home.comcast.net/~amberlani01/ServiceManual.pdf
whats a 2x2??
trans drains approx 3 to 3.2 qts at one time, then you refill-drive 5 minutes using each gear up and down a few times, then drain next set (if doing multiples)
background info like this helps us diagnose your problem- the story has gone from It just started slipping... to- I used something besides honda fluid and now it slips~
I filled it twice with 3 qts of castrol then drove about a mile each time then for the final fill i used oem atf about 4k ago n my car now has 184k....got to school this morning and d5 started blinking then check engine light came on.....i guess im really screwed an need to replace or rebuild the tranny
castrol makes atf?
so you did a drain--fill, then drain-fill with castrol, then fill with honda atf? i would of never mix it even if it said so...honda atf only, these transmissions are so fragile any little thing like grade in castrol oil would cause it.
imo and my experience with my two failed trannies in the past, they died month later after doing a 3x3, and after learning some more about how sensitive transmissions are on any vehcile i never did it again. 3x3s only cause more problems as it fully cleans the internals rather than the fluid alone.
castrol makes atf?
Yup thats exactly what i did, I decided to use castrol cuz it was cheaper and it wasnt stayin the tranny so i figured why not. I shouldve never messed wit it even tho the fluid was black like oil. When i get a new tranny im just gonna change the external filter and the pressure switches and call it a day.
will your wrong if you think that there isn't any Catrol ATF in it because there still is castrol ATF in. When you drain it it doesn't dran the converter and that's why people flush it several times to flush the converter and all the rest of the valve body, so you did more damage than good by being cheap.
good price, labor included? with that one i would just drain and fill in the future....i been threw two trannys on two diff tls, a 99 and a 02, and did 3x3 and they both died within 2 months......my opinion but i know others swear by a 3x3....i know many 6th gen accords with the same issue, and most do drain fill only and still have original tranny.
https://acurazine.com/forums/showthread.php?t=749026
and
https://acurazine.com/forums/2g-tl-problems-fixes-117/cleaned-shift-solenoid-filter-screen-fixed-problem-644943/
The code that came up after d5 started flashing was P1750 Mechanical fault in hydro system....im sure this has been sed like 1000 times by many other people
Damn....thanx for the heads up....still drivin it and hasnt died on me yet...lookin around for a used tranny cuz i really dont wanna pay alot of $ to rebuild
I have never seen this posted before. Back in the last century, in the mid 90's, I drove a string fleet cars. Fords, Chevy's Pontiacs. The fleet rental firm ran thousands of cars for corporations. I remember being told by the fleet service manager when I requested that my GM car was due for a 30,000 mile transmission flush being told that it is forbidden. Their data over thousands of miles of fleet cars had proven that there were fewer transmission failures if you never changed the fluid. Even worse, once you changed fluid on a transmission with more than 20,000 miles, the odds of a failure increased greatly. My daddy used to say if it isn't broke, don't fix it.
Honda Z1 is not that great of fluid. Reason why many Honda transmissions have died is due to heat and the fluid not taking it well. Ever wonder why the cars with Z1 have issues and lots of stuff on the magnet, but then cars with Amsoil in them for many miles have no issues and nothing on the magnets?
Many tests here, and on the Ody forums plus other Honda forums, have shown that other products out there are better than the Honda Z1 fluid. Many think Honda wants people to use the fluid so they can gain money with your tranny failures. But who knows. I just know my car with a Amsoil 1x1 drain and fill from the Z1 stuff shifts easy now vs hard with the Honda stuff it did before. Can't wait to do the next two.
When I stated a while back I change out the 3qts trans fluid with every oil change everyone got on me as a waste of money.
After this thread i feel better.
I am an Amsoil guy, in both bikes and my CRX Si (motor and trans) but i would be nervous switching out the Honda ATF at this point.
Traded in my
Just Honda ATF..and a rebuild might get you by long enough for you to dump the car since the problem is with the case design. The only fix is a 6MT but a better fix than a rebuild would be to get a redesigned case from 05+...check the tranny failure thread for more info...
start it on honda fluid- let it break in on that
Later you may switch but those other oils are extra slippery and not good for initial use
Like a new engine, some wear has to occur for it to work at its best
when my D5 flashed getting on the freeway hard- it didnt do it again and kept running fine until dealer could see it- lets say 2 weeks,
even then they drove it 3 days without incident and finally got an engine overspeed code but engine was not in Limp Mode
which indicated trans was slipping and fooling computer in to not issuing a trans code
They could have smelled the fluid but that would have been too easy
Thats interesting.....sounds crazy tho....I left my car at the shop 2day for them to rebuild the tranny....they sed it should be done by tues
