Timing belt tensioner issues
Hi I have a 2002 Acura TL type s and have been having an issue with the timing belt tensioner, it failed when I got the car and I then replaced it and it failed again within 2 weeks, trying to find out if the idler wheel could be bad causin it to fail or the other tensioner, was hoping to get other people’s opinions before I go throwing money at it
Latent car nut
Received 2,005 Likes
The timing belt tensioner failed, twice, and you didn't bend any valves? Sounds odd.
Latent car nut
well basically the tensioner does not completely fail it just starts making a horrible noise around 1k to 2k rpm and when I pulled the front cover off it was coming from belt vibration so I changed the tensioner and it stopped that belt vibration for a couple weeks and now it is back, I assumed it was the tensioner failing
el.profe
02-20-2020 06:26 PM
kaushiknair
05-15-2013 02:44 PM
