Timing belt tensioner issues
Hi I have a 2002 Acura TL type s and have been having an issue with the timing belt tensioner, it failed when I got the car and I then replaced it and it failed again within 2 weeks, trying to find out if the idler wheel could be bad causin it to fail or the other tensioner, was hoping to get other people’s opinions before I go throwing money at it
The timing belt tensioner failed, twice, and you didn't bend any valves? Sounds odd.
(Post 16391818)
Why is there normally something wrong with the valves if the tensioner goes? |
Originally Posted by Chris Kaz
(Post 16391938)
(Post 16391943)
Yes, if the tensioner goes then the belt will jump teeth and you will bend valves.
I ordered another belt tensioner so I am going to install it and see if it will last longer and hopefully it completely stops the noise |
