Thermostat question opening and fully opening at what degree question....
Does anyone know when the Thermostat starts to open and when is it fully open in degrees? I had my thermostat in boiling water and I believe it started to open at 185 and fully open at 195 ish. My temp gauge might be bad though so I may double check it again tomorrow but wanted to see if anyone here has tested it and when should it start opening and when is it fully opened? Stock Acura Thermostat and it states 78 C on it so it should start to open at 172.4 F. Could anyone confirm.
Thank you
Thank you
