Notices
subframe rust & corrosion - 2003 tl type s
Old 07-05-2019, 11:15 AM
  #41
Registered Member
^^^ If you google "pickup frame rust" you will see that rust is problem at all cars, pickup, sport utility with frame instead of unibody. My Ford 99 has C channel and I use some rustproofing methods at it. From 2004 Ford switch to boxed frame and it is rusting badly. Toyota pickup at other hand rust even worse than Ford and GM. As I said spraying undercarriage work and I will keep doing it. My exhaust at pickup is without rust in 20 Mn winters. Only problem for me is I buy used cars/trucks so I need get it before rust get it.
I checked already my Acura and rust is minor at passenger side. I will do pipes redirection, it is not problem. As I said I'm rust fighting enthusiast and of course I checked for rust long time go. It is minor rust there. Only if I would know it is some rust problems at acura and Honda I would pull out my rattle cans of my gun belt earlier. In this neck of the woods rust do not stand chance.
bbsitum is offline
LECKEY73
02-22-2016 01:32 PM
Ponsey_Scheme
Second Generation RDX (2013-2018)
32
10-23-2015 09:16 PM
IIDXholic
10-08-2015 07:53 AM
2G-TL-Type-S-03
09-20-2015 12:48 AM
Quick Reply: subframe rust & corrosion - 2003 tl type s
