slight clicking sound when turning the steering wheels.
Old 03-01-2009, 06:10 PM
guyenacurazine's Avatar
It is more evident when I start up the car and steer the wheels. I am pretty sure it is not axle because the sound is not coming from underneath but rather from the direction of instrument panels.
Does anybody have any idea? Thanks!
Old 03-01-2009, 06:33 PM
wham bam thank you ma'am
Rajca's Avatar
its normal. you should have several click sounds when u turn the wheel, how many clicks depends on how far you turned the wheel.
Old 03-03-2009, 09:52 PM
here comes the snow!
sfont012's Avatar
man every time i turn my steering wheel i hear something coming from below but not the dash area. i have no idea what it is.
Old 03-04-2009, 06:36 AM
totaledTL's Avatar
Clicking from front wheel area when turning usually indicates worn CV joints.
Old 03-04-2009, 07:29 AM
BensTLS's Avatar
Check your lower ball joints. Looks like it's time to replace them before they break on you. I had a lex gs400 and it had clicking sound every time I turn the wheel or sometime when it goes over bumpy road. Unfortunately, my wife drove the car one day and the lower ball joint on the driver side broke off. It f*** up the whole driver side, front suspension, fender, door couldn't open, rocker panel....man the list goes on. Insurance company totalled it.
SO, check your lower ball joint and replace them when you get a chance.
Old 03-04-2009, 05:47 PM
Rajca's Avatar
does it only click when u turn the wheel and the turn signal is on? or at any time? sound is comming from the inside or outside of the car.
Old 03-04-2009, 07:45 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
are you stopped and turning the wheels- thats hard on the pump and rack!
are you moving forward slowly with the wheel cranked full- click click click
thats cv
there is a cv bearing at the trans end of each shaft too, so it can sound like dash
Old 03-07-2009, 01:03 PM
pretty sure it is not CV joints, because i had it before.
when CV goes bust, clicking comes only during acceleration. Juust turning the wheel during stop will not click.
Old 03-07-2009, 01:04 PM
i think it comes no matter turn signal is on or off. it is definitely coming from inside.
Old 03-07-2009, 01:06 PM
thats cv
i know i usually avoid turning the wheel when stopped, but as you know, sometimes it is necessary.
the sound comes when stopped or moving i dont believe it is CV, if it is CV, then it sounds only during when I am accelerating not cruising.
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
Iain MacLeod
09-17-2015 01:01 PM
PortlandRL
09-14-2015 12:01 PM
sputik
09-07-2015 01:40 PM
Quick Reply: slight clicking sound when turning the steering wheels.
