Simple question about Timing Belt Kits
Old 10-27-2013, 05:21 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
I'm in the market for the OEM Timing belt kit! my car is almost due for the 205K job.
Now the issue is that my first and second (60K and 114K) timing job was done at the dealer but this time I want to do it myself to save the labor..
The issue is I don't want to spend that much in parts (less than 450 bucks if possible) but I cannot find a specific OEM KIT at ebay for the J32A2 there is only for the J32A3 (Acura 3G TL 3.2) is there any difference at all?
This is the kit
http://www.ebay.com/itm/Genuine-OEM-Complete-Timing-Belt-Water-Pump-Kit-Honda-Acura-V6-Factory-Parts-/161120327788?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AAcura%7CModel%3ATL&hash=item258385186c&vxp=mtr
Thanks for any Input in advance!
Old 10-27-2013, 05:46 PM
victus1's Avatar
Not that one. What you want is the Aisin TKH-001 kit which has all the OEM parts. It goes for under $200....sometimes around $160. This is the one I installed and others here too.
Old 10-27-2013, 05:54 PM
Skirmich's Avatar
Like this one Victus? http://www.ebay.com/itm/Acura-CL-MDX-TL-3-5L-3-2L-V6-Aisin-OEM-Timing-Belt-Water-Pump-Seal-Kit-NEW-/251309627130?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a833896fa&vxp=mtr
Old 10-27-2013, 06:46 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Or you can contact our vendor for one as well
https://acurazine.com/forums/2g-tl-1999-2003-98/complete-timing-belt-kit-special-%24295-763444/
Old 10-27-2013, 06:58 PM
Skirmich's Avatar
^ I drop him a PM... In any case thanks both for your replys.
Old 10-27-2013, 10:01 PM
victus1's Avatar
Originally Posted by Skirmich
Yeah, but I'd try to find a better price. There's one on ebay for $189. Prices seem to be all over the board. As long as it's TKH-001 it has the proper OEM parts. Amazon has one for $218 and free shipping.
Aisin TKH-001 Engine Timing Belt Kit with Water Pump : Amazon.com : Automotive Aisin TKH-001 Engine Timing Belt Kit with Water Pump : Amazon.com : Automotive
nats007 (10-29-2013)
Old 10-27-2013, 10:39 PM
Skirmich's Avatar
^^ That's a great price! Thank you. I think ill go for that one.
Old 10-27-2013, 11:29 PM
Unregistered Member
Karanx7's Avatar
Keep in mind some of these kits don't have OEM parts. For example, that amazon link has "OEM Matched" parts, which just means not OEM at all.
Old 10-27-2013, 11:40 PM
Skirmich's Avatar
^ I see the Mitsuboshi timing belt which is the same as OEM..
The Idler and Tensioner are both KOYO which are OEM.
Quote:
""Kit Includes: AISIN Water Pump, AISIN Hydraulic Tensioner, Koyo Idler Bearing, Koyo Tensioner Bearing, Mitsuboshi Timing Belt.""
Old 10-27-2013, 11:56 PM
Unregistered Member
Karanx7's Avatar
Weird I don't find that quote on the amazon site? Either way, they should be good if they are made by the OEM manufacturers.
Old 10-28-2013, 12:20 AM
Skirmich's Avatar
Nah that its on the EBAY sell since the kit its a bundle "TKH-001" I believe Amazon sells the same stuff just cheaper, Like always
Old 10-28-2013, 11:18 AM
lsiravi's Avatar
Confirm this. I bought the same kit from Amazon a couple of months or so ago. Came in a couple of days (must be an Amazon local merchant or something). I didn't do the job myself, but the mechanic who did the job said it was indeed OEM and the same as what he would have put in. I think he mentioned something close to $300 as cost of parts.
Old 10-28-2013, 03:31 PM
Mr.Helpful Diagram
ErickUa5's Avatar
Here's the catalog from Aisin http://aisinaftermarket.com/uploads/...7872947_en.pdf
Old 10-28-2013, 03:47 PM
Skirmich's Avatar
Yah since its sold as a Kit "TKH-001" it must come in a sealed box or something not a handful of handpicked items... That why I believe the Amazon package is the same as the Ebay one.
Originally Posted by ErickUa5
Thanks! Now its confirmed I need the TKH-001..
Old 10-28-2013, 06:08 PM
3.2TLc's Avatar
Yeah, just shop for the best price as Victus1 earlier stated and you'll save some bucks for the coolant and other misc. things that ya decide to replace while the everything's opened up at the time.
Good luck, and if ya come up with any tips or shortcuts along the way, please pass them along to other potential DIY'ers !!!
Old 10-28-2013, 07:13 PM
victus1's Avatar
I would also recommend you change the front crankshaft seal during the tbelt service. It's right there in front of you and the seal is cheap straight from the dealer. Use a drill to drive a screw in it and pull it out with pliers so you won't scratch the mounting surface. Then oil the new one and use a small mallet to lightly tap it in place.
It's also a good time to change the serpentine belt and tensioner....and the power steering belt. I installed the Gates premium belts for around 10 bucks each and the Gates tensioner (OEM part) for around $55.
3.2TLc (10-29-2013)
Old 10-28-2013, 07:17 PM
Skirmich's Avatar
^ I actually was considering in getting the Lightweight pulley but Seals are a must! I will do Cams and Crank seals just crossing my fingers so I can get the pulley by the time I do the service.
Tensioner and Belt was done around a year ago so Ill re-use them.. Need to change P/S Belt tough still riding the 11 year old original
and 3.2TLc
Yah Im going to change FULL A/F + Thermostat..
Old 11-02-2013, 02:07 AM
bob441's Avatar
difference between 1999 and 2002 water pump kit??
Okay I am a newbie what is the difference between a 1999 and 2002 order pump kit for a Acura TL? the reason I asked is that have a water pump kit for 2002 here already and want to install it on a 1999 that needs a water pump( I have two cars a 1999 and a 2002) you all have a great forum and I'm learning a lot about the cars thanks Bob 441
Old 11-02-2013, 04:46 PM
3.2TLc's Avatar
You should be able to cross reference the part # for the water pump easily.
Chances are that it's the same, but just to be sure....check out compatibility.
Old 11-02-2013, 09:21 PM
Gabru678's Avatar
Woah now there are crank seals?
Can we get a list of everything that should be done?
I have:
- Water pump
- Power steering belt
- Timing belt
- Tensions
- Bearings? (Which Specifically?)
- Adjust Valves
Anything else?
Old 11-03-2013, 09:27 AM
victus1's Avatar
The crankshaft seal is right in front of you when you remove the timing belt. It would be a crime not to change it since it's cheap and only takes a few minutes. Like it would be a crime not to change the rear main seal when you remove the transmission.
As for adjusting valves....I wouldn't do them at the same time as the tbelt. Finish one job, make sure the car runs fine, then start another job.
This is what I changed when I did my timing belt:
I used the Aisin kit (timing belt, water pump, tensioner, tensioner pulley, idler pulley)
Power steering belt, serpentine belt and tensioner.
Crank seal
Crankshaft sensor (again, because it's right there and easy to change and prone to failure with age)
Old 11-07-2013, 09:01 AM
Mr.Helpful Diagram
ErickUa5's Avatar
The 99 has different tensioner iirc I think everything else is the same.
IIDXholic
10-08-2015 07:53 AM
wusty23jd
09-24-2015 11:41 AM
merc009
09-14-2015 06:43 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: Simple question about Timing Belt Kits
