Seafoam vs Lucas vs Techron concentrate: Got a favorite? If so tell why!
What product named or not named above do you prefer for fuel system cleaner? and why do you prefer it over other brands?
I am familiar with lucas and seafoam but recently the guy at the store recommended strongly techron concentreate plus, he was really ranting and raving about it so thought I would try it.
Tell us about your experiences and preferences for these type of products?
assuming your talking about "lucas fuel system cleaner" (white/blue bottle) but what do you think about "lucas fuel treatment" (see through bottle with yellowish fluid)??
SeaFoam........
Yeah, gotta agree .....it's on top with Ziner's, if ya have not yet read the previous threads regarding it's recommended use....check out by searching !
PS, by the way...."BG" is also a good product, often offered at dealerships.
I agree with 3.2TLc with regards to bg. Personally I like bg, wynns, techron, and redline over seafoam, although I've used them all. Techron comes in a variety of strengths, some more consumer oriented, some more professional. Techron is also the only one I've seen recommended by any oe manufacturer. Many of the oe mfgrs have their own branded fuel system cleaner. The last time I looked, the gm bottle looked suspiciously like a techron bottle. I haven't used or heard much about lucas fuel cleaner, but I've band-aided a couple transmissions with their transmission glue,.... er, ah, I mean transmission additive.
3.2TLc (06-14-2013)
How much impact do you guys think ANY of these fuel system cleaners really make? for 10-15 dollars bottle on average is it worth the buy?
Do any of you use fuel system cleaner regularly? Like once a month?
2006 NBP TL MT6/ 02TL-S
In my totally unsupported, non-scientific-based opinion, most of those mentioned are good FUEL SYSTEM CLEANERS. (I'm also not sold on the Lucas stuff)
My experience in running 2-cycle V-6 outboard boat engines over the years leads me to believe that SeaFoam does a better job at DECARBONIZING the entire engine, not just cleaning the fuel system.
Very self lubricating too ( not too harsh on the silicon/rubber parts of ur engine).
i once heard my mechanic tell me that buying those cleaners is no different than buying expensive repackaged kerosine.
he said i could mix some kerosine with a lil bit of 10 30w oil and get the same benefits but i choose to go the sea foam route anyway ...........
I wouldnt be surprised if you was onto something. I'd rather just buy it in the store to.
look how much of other products are required to equal one can seafoam,
which is the stuff used in machine systems at the dealer!
instant decarbon of intake valves and pistons with spray and longer term scrubbing of lines with gas tank method
amount is critical
fuel 2 oz per gal Cleaning dose = 1 can to just under half a tank fuel
oil 1.5 oz per qt = 1/2 can to 5 qts 30-200 miles before change
amount is critical
midyear dose of 1 can to 16 gal is maitenance dose
ok to do as 1 can to half tank if desired instead
on a new car I agree with what you said probably not that necessary to use much or at all. But with cars over 100k miles thats a different story. Cars near or over 200k miles another one.
Sold !!!, so what do ya think.....?
So ya apparently bought Techron......have ya tried it as of yet ?
If so, are ya pleased with the results of the product as ya were sold ? Would ya recommend it's use on our older cars ? Being familiar with Lucas and SeaFoam products......how would you compare the Techron's claims and your observed results ? Is it worth the money......or merely snake oil ? fill us in on the details !
chevron makes techroline and adds a maitenance dose to pump fuel
our cars are old enough to need constant cleaning- stupid ethanol added to fuel eats parts, leaves behind a lot more unburnt material to settle on the valves and pistons, and clogs lines
parts counters rave about whats on sale- has bonus commission that month
seafoam simply works
techroline and stp come in a 3 bottle pack for a reason
made so weak it takes 3 to = 1 seafoam
3.2TLc (06-12-2013)
3.2TLc (06-14-2013)
fuel cleaner products.....
So, how was the Techron ?
You've asked us, now tell us your thoughts on the product which you bought and tried !
Hard to say. 1 bottle isnt going to really make a big noticable difference so hard to say for sure. I think that when I change the spark plugs though that could make a good difference.
Techron.....
Yeah, gotta agree.... if your system isn't really dirty, ya won't notice a difference. So ya didn't get the "BYGO" free offer ? Usually with a product like that, it may take the second bottle to realize any effect.
yea approaching 200k miles so I think its not a bad idea to use these type of products every once and again.
What do you think about those little bottles of fuel octane booster? stp makes a line that comes in a orange bottle. Ever use any? For high performance vehicles and sportscars they may be much more benefical is my guess.
do not use booster in the TL for street use
seafoam in gas gets everything clean- over a longer time period of a week or two as fuel is used up
the old method thru vac port gets instant results on some parts,,,but misses entire fuel system,,so do fuel only or a bit of both~
dont forget the throttle air plate is seperate cleaning job and important!
vac port method done thru tb throat will take care of that!
acuratl26
04-23-2020 07:30 PM
