Seafoam Question
Pimpn' Ain't Easy
Seafoam Question
So Seafoam goes directly where the oil is placed. The website says to put SeaFoam in 1 hour prior to an oil change.
Does anyone have experience with this product. I have read the past threads and they seem to be in conflict.
Anyone with any new experiences?
Here you go, all the info you need is on that thread.
https://acurazine.com/forums/showthr...hlight=SEAFOAM
No He Can't
You can put Seafoam in the gas take, vac line, and/or oil crankcase. When you put it in the crank case, you should go get an oil change right after, just like the web site says. If you put it in the gas tank, you don't really need to anything. A half to full can in 1/4 tank of gas should do the trick. When you put it through the vac line, after you let it sit for a few minutes, you need to go on a high RPM run and hit vtec a few times to heat up the engine and burn off all the Seafoam and gunk that it has loosened up.
Look for the thread called "Seafoamed the ol TL", it has a lot of good info in it.
Agree
The Gen 2 thread " Seafoamed the Ol TL" has 14 pages of pics and arrows and tips to do this simple DIY
Never heard anyone say it didnt help- just - wow this stuff is amazing
I run 1 can in the gas tank with 1/4 tank of fuel- cleans injectors
1 can in the intake vac line to super clean engine valves and pistons
and then some in the oil to remove sludge and gunk from oil passageways
Do it again in 2-3 k miles and really feel the results
acuratl26
04-23-2020 07:30 PM
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
