Notices
Replace/reposition Nav climate controls
Old 05-04-2019, 11:33 AM
Registered Member
darkdeuce's Avatar
Looking to remove the Nav dash unit and retain the ability to control the fan and a/c .
I plan on keeping the housing (replacing with a tablet) and the lower controls just above the radio.
IS THIS POSSIBLE?
darkdeuce is offline
Old 05-04-2019, 12:16 PM
Registered Member
whitetiger5's Avatar
As you may already know...the navi screen controls the manual HVAC operations (fan, a/c: on-off and ventilation directions). in the non-navi model, those controls are handled by the analog dial that is nested in the same place of the dashboard that your current navi screen is located.
that being said, I think that it could be possible to replace that part of the dashboard with the manual controls, but not have both.
If you want to place a new aftermarket tablet, I believe most who've done this place a double din tablet right below the stock navi screen.
I think there were some at some point that were able to find a screen unit that allowed interfacing with the oem HVAC system, but I think the solution was rare, pricey and no longer available.
whitetiger5 is offline
Old 05-04-2019, 12:37 PM
Registered Member
darkdeuce's Avatar
whitetiger
I'veseen this as mainly software issue as there is a touch screen.
Can't this be hacked?
Old 05-04-2019, 01:35 PM
Registered Member
Iggy's Avatar
Reverse engineering of the NAV A/C controls had been attempted years ago but I never saw any outcome that could be readily replicated without major time and expense like whitetiger mentioned.
A few options:
* Leave the Nav where it is and put the tablet where the radio is(not the greatest position for viewing or controlling while driving but the easiest if dead-set on a tablet)
* Move the Nav to the radio position(considerable work involved) and install tablet in the old Nav position.
* Delete the Nav and replace with non-nav A/C control head relocated to where the radio is(again, considerable work involved)
* Forget the tablet and install a Double din stereo unit with bluetooth, handsfree, Apple & Android connections, retain factory steering wheel radio controls, etc.
I went with option 4:
Iggy is offline
Old 05-04-2019, 02:53 PM
Registered Member
That sucks but hey at least you can turn your old TL into a poor-mans TLX lol
Darksyne is offline
CL-Slick
Second Generation TL (1999-2003)
01-07-2019 02:58 PM
ajorona
06-04-2018 03:30 PM
frostbitten
Second Generation RL (2005-2012)
02-02-2018 09:21 PM
jermo537
1G TSX Problems & Fixes
02-27-2017 05:31 PM
01clsblackUOP
02-28-2005 06:47 AM
Quick Reply: Replace/reposition Nav climate controls
