relearn, low idle
Old May 29, 2012 | 02:32 PM
dreem1er's Avatar
deal with it
relearn, low idle
i recently did a trans drain fill, changed the filter, put a trans cooler, cleaned the throttle body, and manifold installed a throttle spacer, and catch can, had my battery disconnected for about 3 days while i did this, i was working so i was in and out and took forever to do it all..
i have everthing back in and my idle is at like 1-200 drove around and the shifting seemed ok and got better as i keep driving but my idle is low as hell
Old May 29, 2012 | 02:40 PM
swoosh's Avatar
takin care of Business in
^^^ the ECU needs to relearn the idle rpm....
how you do this (in the 3G) is:
connect your battery
turn the car on
DO NOT TOUCH THE GAS PEDAL
AC OFF
leave it like that for 3-4 minutes
if you didnt do the relearn what i suggest is resetting the ECU (remove the battery) again for 15-20 minutes and then follow the relearn process....
Old May 29, 2012 | 04:03 PM
Skirmich's Avatar
If it doesnt come back you must re-do Throttle Body + IACV something got wrong there.
Old May 29, 2012 | 04:25 PM
dreem1er's Avatar
deal with it
Do i have to adjust the cable when i do the spacer?
Old May 29, 2012 | 04:27 PM
swoosh's Avatar
^^^ This thread should help you out:
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-thermoblok-spacers-install-egr-cleaning-615644/
Old May 29, 2012 | 08:55 PM
dreem1er's Avatar
deal with it
well i figured out that i'm a retard...also that my ivac was messed up
this is the spacer
this is what i took out and didnt think twice about
basically i shouldn't be allowed to have kids, i removed the spacer because i'm not going to do a rig to get to work without the chambered piece, all i need is longer bolts and i can put it back in...also i had the ivac and i think its just done for i may need to replace it
Old May 30, 2012 | 09:59 AM
swoosh's Avatar
08KBP_VA
Oct 22, 2019 01:55 PM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
Rcelestino93
Sep 23, 2015 10:01 PM
