Radio & Lighters no power???
Hi all Im new here. My 03 Type S radio and lighter plugs are not working. I've checked the fuse on the driver side it was good. Checked the fuse on the passenger side it was good and the taller 40 fuse under the hood it was good as well. I also took the dash out to see if i saw any exposed wire. Nothing pls HELP.
Try checking the circuit diagram in the service manual (22-198)? There's another component in the system that is controlled by the ignition switch.
I just got the car a lil over a year ago and it didn't come with the manual. Im a nit of a novice one i locate that what am I then looking for to then correct.
how did you check the fuse?
1st I checked them visually then, I put those fuses in same rated slotes of other components to see if they still work and they did.
Which slot did you check?
Originally Posted by MrSix
(Post 16401878)
https://owners.acura.com/vehicle-information/ On my 2001 manual, fuse box layout is on pages 280,281 in the "Taking Care of the Unexpected" section. |
