Quick help!!!!
Quick help!!!!
99 acura tl.. when I got in the car this morning NOTHING WORKED... well i was able to start the car and drive and the radio and the heat workes but.... WINDOWS, DASH, ANY BUTTON NEAR THE DASH (CC,TCS BUTTON) and intrument cluster and i could not get out park without the override feature.. now i changed the ignition switch lately could that be the culprit??
Mr.Helpful Diagram
That fuse gave up for a reason, any work done or mods ?
May have shorted something out during the recent switch replacement ?
it made anything inside the car not work except the clock,radio, hvac system... so that must be a major fuse.. i had to drive over 45 miles before checking it ( i know it was dumb...) i hope that fuse didnt control any of the radiator fans.... cause now asfter it was replaced i am feeling studdering on low rpm driving 1-2.. i did the tune up 5 months ago and done everything on the diy section on this fourm... so I guess i messed something up
WELL........ the fuse was the 7.5 acc relay fuse.. first time it ever blew. does that fuse contol engine electrics too? like the fans on the radiator? yes i am very scared if it did.. i had to drive from dallas to ft worth TX (about 45 miles) without seeing anything working on the dash...
OUCH! ACC fuse could well end up being a problem in your Aftermarket Radio installation.
ACC Fuse controls most base voltage level for: Dashboard, A/C, Radio, Ignition, Etc... It doesn't control line level voltage (Thus why its low Amperage) but its basically the master base voltage to control live full 12v Voltage Relays and Stuff.
I would re-check all stuff in your Radio Installation as IF the ACC fuse blow up while driving your car will automatically turn off.
Its weird because if ACC blows you should not be able to start the car as the Ignition Key should have no power.. BUT I don't know if killing the Ignition will still allow power to run from Key Position II which runs the A/C and can turn on the Fans..
This will be far better explained by an Electrician using the Electric Diagrams.. In any case if you didn't run the car too much don't worry as long as the FANS where on the Engine should had no problem being cooled down.
TLguy42
09-26-2015 11:27 AM
