AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   2G TL (1999-2003) (https://acurazine.com/forums/2g-tl-1999-2003-98/)
-   -   Question About Lower Ball Joints (https://acurazine.com/forums/2g-tl-1999-2003-98/question-about-lower-ball-joints-708831/)
TACURA 02-06-2009 02:16 AM
Hey guys. I bought a pair of lower ball joints from my local shop. Do lower ball joints usually come with a castle nut and cotter pin?
These have neither. Just the ball joint and grease. Does it matter?
http://img264.imageshack.us/img264/8128/18693240jl2.jpg
SodaLuvr 02-06-2009 04:04 AM
I don't remember, but on another Honda that I did ball joints on, I think I reused the original nut.
I can't tell what brand ball joints those are, but I highly recommend Spicer Professional or Moog ball joints.
fsttyms1 02-06-2009 07:19 AM
I see it has a lock nut. Id still rather have a cotter pin. Is there a hole in the ball joint for the pin? maybe reuse the OE nut?
TACURA 02-06-2009 08:08 AM
McQuay-Norris is the brand.
TACURA 02-06-2009 08:11 AM
It's weird. There's not even a hole for the cotter pin. Do you think it's still ok to use without a cotter pin?
fsttyms1 02-06-2009 09:34 AM
Should be with the locking nut
totaledTL 02-06-2009 02:45 PM
Castle nuts used w/ cotter pins.
Aznfury 02-08-2009 01:51 PM
just buy it from the dealer, they arent expensive at all, and the ones from the dealer comes with new cotter pins, just gotta reuse the nut, but thats no biggy, and remember there is a special tool to put the ball joint back in without ruining the boot.
TACURA 02-09-2009 05:08 AM
The dealerships around here won't sell the lower ball joints without the lower arm. So I just order some OEM ball joints from ebay.
Thanks for all your help guys.
acutee 02-09-2009 09:57 AM
Your balljoint comes with the secure nut, that is why the balljoint was not designed with a hole for the pin. You can see the white plastic in the nut.
thinhthan 02-09-2009 03:33 PM
it should come with the nut and pin
kidduce 02-09-2009 05:02 PM
I actually just did mine the other weekend and yes they came with a new castle nut and new cotter pin. I don't remember what brand they were but I got them from my local auto part store, Napa.
TACURA 02-09-2009 05:11 PM
Ok, cool. Thanks for all your responses. Much appreciated.
I just went ahead and returned these. Then I bought a pair of OEM Honda Ball joints just to safe. About the same price also.
Aznfury 02-10-2009 10:20 PM
actually the dealerships DO sell just the lower ball joints by itself, the part number is 04510-s84-000 trust me, i work at honda, it comes in a kit...
TACURA 02-11-2009 01:43 AM
Yes, you're right about them selling the ball joint by itself, but only at certain dealerships do they do that. I've called both Honda and Acura dealers around my area, none of which do.
silver2003tl 03-26-2010 03:03 AM
Did you guys see this thread? https://acurazine.com/forums/2g-tl-1999-2003-98/i-have-creaky-squeak-left-front-suspension-any-ideas-633975/
Apparently there is a tsb here: http://www.in.honda.com/Rjanisis/pubs/SB/B06-015.PDF
The tsb shows the ball joint is 06523-S84-405.
Which one is right 06523-S84-405 or 04510-s84-000 . Are they the same thing? One is Acura other is Honda P/N???
I'm pretty sure because it looked pressed in, and I don't see a B (but not sure where to look), but I might as well ask - This one is replaceable right?
http://home.comcast.net/%7Elorenzana...3/DSC_1192.JPG
TACURA, if you want, and if it's the right part, you can find them online: http://www.hondapartsnow.com/genuine...3-S84-405.html
swalch@stanford.edu 03-26-2010 07:50 AM
The shop manual doesn't seem to suggest replacing the lower ball joint, but rather the whole knuckle assembly. The ball joint certainly is replaceable after the knuckle assembly is removed from the car. The Moog ball joint has the snap ring, castle nut, and cotter pin. I would use a type with a castle nut.
silver2003tl 03-26-2010 09:06 PM
Did you read the TSB? It shows that ball joints not stamped with B can be one time replaced. The TSB also says to use P/N 06523-S84-405, but Aznfury mentioned something about P/N 04510-s84-000 so not sure which to get.
silver2003tl 04-18-2010 01:59 AM
Just to close the loop for someone in the future...
I went and bought P/N 06523-S84-405 from eBay and it fit great. These new ball joints do have the letter B stamped on them. The originals do not have a B so that's how they keep track.
Pressed them in/out with a rental too from Advanced Auto Parts. Autozone one only had 3 tubes that didn't work. Advanced kit was Alltrade 940579 (10 piece kit) which worked much better. Maybe not essential but take off the boot b4 pressing the old one out.
Lower ball joint separated from lower control arm via 1-1/16 tie rod separator tool. 1-1/8 one I used first kept slipping off because it was just a tad too wide.
nevTL 02-22-2012 08:45 AM
Just bought some Moog lower ball joints, and redoing a lot of suspension parts in a few days. Is it suggested that I replace the lower control arms while my mechanic is down there?
03 TL-S 130,000 original everything.
RC99TL 02-22-2012 03:47 PM
I am doing new lower ball joints and wheel bearings. I bought the knuckle joint combo.
nevTL 02-23-2012 01:27 AM
Can you link me to that?
Skirmich 02-23-2012 06:32 AM
Originally Posted by silver2003tl (Post 11861928)
That Knukle looks Dangerously Rusted, You should replace it instead of the Ball Joint.
Knukle comes with Ball Joint anyway.
nevTL 02-23-2012 11:27 AM
Need to know if these look good for my 03' TL-S. Much cheaper than the OEM ones! Experts, shed some light...
http://www.ebay.com/itm/Honda-Acura-...ht_1834wt_1173
TLer trash 02-23-2012 02:09 PM
I gotta disagree. Looks like cosmetic, surface rust to me. You'd have to lose a lot of material from that casting before it became unsafe.
Skirmich 02-23-2012 03:45 PM
Look where his ball joint sits on top, It isnt even.
If I were him I would be more concern about that, than the Ball Joint Itself.
But thats Me.
TLer trash 02-23-2012 05:18 PM
Yeah, I didn't really notice that. I'll have to look at another to compare.
nevTL 02-23-2012 05:50 PM
Can anyone help me out with this?
