PSA corrosion build up by OBD2 port
So I noticed when I plugged my OBD Scanner in my car, a bright green spot caught my eye and it turned out to be a massive build up of corrosion by a 3 wire ground connector. Check it out on your cars your 2G TL's could have corrosion build up in the same spot and might never notice.
Never noticed this before but was probably building up for years.
Zoomed in
Had to do a ghetto fix with electrical cleaning spray and a tooth brush to clean the corrosion.
Sprayed battery terminal protector to prevent the corrosion from coming back.
Zoomed in
Just thought I'd let others know to check that ground connection before electrical problems happen, since the OBD port is covered so most people won't even notice it.
