Power Steering Fluid Leak help plz
So my power steering has been leaking for a while and I have been ignoring it because of bigger things I have to take care of. I have just been buying refills and filling it up whenever it got low. Today I got some power steering fluid and popped the hood, and the PS fluid was everywhere! It looks like its coming directly out of the fluid reservoir. Right out of the top? Anybody have any ideas? I thought it was a hose until today. So i filled it up and it all leaked out by the time I got home! It is very bad now. Any help would be appreciated
With it topped off and hood open start the car and see where its leaking from. Have someone turn the wheel lock to lock and look for the leaking. Once you pinpoint it we can better help you.
high pressure hose is first suspect
I was thinking oring until the amount of fluid it is losing, and the fact another ziner needed a high side ps hose last week--these things tend to run in series:
When I was a tech, several cars would come in the shop with the same problem for a week or two,,then a different prob for most of next weeks!
example: a bunch of master cyls, then maybe head gasket week, then bad gas problems..
It was weird
BUT
we can hope this is a minor oring sealing issue!!
It was weird
BUT
thnx you guys i got extremely busy so i havent had an opportunity to check it out but to totaledtl ya i put too much. I filled up to about half an inch above the max level. That could be why it came out of the top, but why did it all come out, as to just whatever was over.
It was weird
BUT
It was weird
BUT
I also have a P/S leak. It looks like its the pressure hose. Part# 53713-S0K-A04. About $100 for a new one. I'm not sure if i should tackle it myself. I may ask the local shop for a quote.
if you can reach the bolts you can do the job~
Its simple to bleed the system after hose install
TIP: place cardboard under front wheels to reduce surface friction
pump out the old fluid via the return line to res bottle, with engine running at idle as you turn the wheels back and forth lock to lock to purge the full system
It wont hurt anything to run with no load and no fluid for a few seconds- per acura method
any fluid would end up all over the place if you dont pump it out first
My parts will get here on Tuesday from AcuraAutomotiveParts.org. I should get it done sometime this week.
Is anyone else doing this? I've seen a lot of power steering threads lately. lol
problems seem to run in groups at a time,,batteries, alternator failures, ps pumps,,,,
In shops its like that all the time, cycles of problems-
when you can figure out whats next and have parts in stock- thats a smart shop
soria - pls leave the type the regular size,,larger is kind of blaring,,unless you need it to see when writing,,thank you
the tension on the ps belt is critical- its often set too tight,, with pump bearing failure soon after
There is a measured slack spec for it
IM BACK GUYS! i know you missed me i have decided to get a new pump. i am replacing right now. how much ps fluid does it take after draining? i have 2 quarts im not sure if thats enough though. anyways, i will drain it first and replace the pump and get back to you guys. if anybody knows that fluid amount needed, i would appreciate it
Here is the tip for you. Trust me, if i were the mechanics the pump will be shot in a few weeks, either they lack of skills or careless about your car. If it didn't break out the door, they're off the hook; now it is your probl. not theirs. Come back for pump warranty exchange, and they will charge you labor.
Re-Install:
1. Don't leave the bottom bolt too loose, it must be slightly tight that you can adjust the pump by hand. If it was too loose, you cant predict the tension when the bolt is tightened.
2. Never use the tension bolt to put tension on the belt. Tighten the bolt under the ps pump will put tension on the belt itself.
3.If doing so didn't give it enuf tension on the belt, use your hand and pull up the pump.
Re-Install:
ok so i changed out the new o rings and put the new pump on, only to find that the threads for the pulley on the new pump are F*(^&*(^cked up. so i put the old pump back on with the new o rings. so we will see if im still leaking. ill let you know tonight if i have issues or not.
Unregistered Member
It's coming from underneath the PS pump, or on the bottom side of the car? If it's coming from a hose located under the engine, I think you will need some professional help.
My hose connected to the top of the PS pump was replaced, and it took my mechanic many hours. And that's probably the easiest hose to replace =[
ya it's leaking from under the car. at the power steering unit? it's coming directly out of the top of it. it is located at the bottom of the car. It's connected to the rack and pinion. Either way, it's going to be a huge pain :| that thing has so many hoses connected :| and it's connected to the rack and pinion.
Unregistered Member
I don't think anyone else has had that problem, so there might not be too much help available. Your best bet will probably be a professional mechanic. It will most probably be expensive, so you might wanna find exactly where it's leaking by yourself. That way, you can just buy the replacement part, and have someone replace it.
Park your car over some cardboard/paper, and pinpoint the leak. Trace the leak back to the part. It should have some burnt PS fluid around the leak. If it's a big leak, you'll need to replace it. If it's a really small area, you can try using Stop Leak.
Stop Leak isn't the most ideal stuff, but if it can work, you'll save hundreds.
is it leaking from a rack seal? ckd the boots on the ends- lift edge and if fluid comes out--bad news
how did the old fluid look-- crudded-black?
of course the lines hook to the rack!! power steering assist--steering rack~ hydraulic fluids...
no it is not coming from the actual rack or the boots. it is coming from the steering unit boot. where the steering wheel is actually coming down to and connects to the rack. it is a small leak and it is leaking my new fluid :| yes i know i am stating the obvious, but I am trying to describe it as best as I can so I can get some good help.
Clean off all residue surrounding the power steering area. Then put in UV dye. Put on your UV shades and find the leak. It should be very easy to find.
If you have a significant leak, you'll probably end up needing to replace the rack/hoses/orings/etc to fix depending on what it is. I had a leak out of my rack that would bring the reservoir down from the top mark to the bottom mark within a few weeks or so, and I used some Lucas power steering stop leak and it's been fine for about 10K miles now. But I think this will only work if your leak is relatively slow, and through a seal that can be reconditioned with the stop leak.
https://www.amazon.com/Lucas-10008-P.../dp/B000ARPVNO
mike from annapolis
05-07-2017 08:21 PM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
