Power Steering belt replacement
I am needing to replace my power steering belt. I believe i understand how to replace it but i want to be sure i am doing correctly.
To remove the belt you loosen the pump adjusting bolt, mounting bolts and nut on the steering pump and slip off the belt.
Here is where i have the question. once the belt is on do i tighten the mounting nut and bolt down first, then tight turn and tighten the adjusting nut to get the proper tension or do i turn and tighten the adjusting nut tight first then tighten the mounting nut and bolt? any advice would be gratefully appreciated. thanks.
https://acurazine.com/forums/3g-tl-p...-scans-841134/
Not for the 2nd Gen TL but similar process can be followed
doh, my mistake!
It wouldn't make sense to tighten the adjusting nut and then the mounting nut/bolt because now the tension would be different. Mounting nut first and then tension nut
Drei
05-06-2017 10:16 PM
lucky777
01-16-2017 11:30 PM
dudeinaTL
10-28-2016 01:03 PM
