PCV valve good or bad
Old 09-12-2011, 08:37 PM
brnm8brn's Avatar
how do i check if the pcv valve is good or bad 01 TL
Old 09-12-2011, 08:53 PM
brnm8brn's Avatar
the one i pulled out i can only blow thru one side, went and picked up a new one and can get air thru both sides
Old 09-12-2011, 10:48 PM
brnm8brn's Avatar
nevermind went ahead and put the new one on and it was bad after idleing for a couple of minutes started hearing ticking noises coming from underneath the car cel and tcs came on, ,cleaned the old one and put it back on until i can get an oe valve
Old 09-12-2011, 11:41 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
the normal test is to shake it- ball inside should move freely
Clean with carb cleaner or deep creep,
or replace with parts store unit under 10 bucks iirc
Old 09-13-2011, 07:19 AM
brnm8brn's Avatar
sprayed some cleaner thru the old one put it back on seemed to work better, the new one i got at the zone is going back, i think i have a vac leak somewhere just gotta find it
Old 09-13-2011, 09:45 AM
acutee's Avatar
It is just a simple valve, a spring and a ball. If your valve is bad, it could be an indication of your engine operation is not that good.
I don't believe the valve will allow air go to both ways. More like a backflow valve.
Old 09-13-2011, 03:27 PM
brnm8brn's Avatar
your exactly right the airflow is only one way, finally found that out today, anyway just didn't know for sure
Old 09-13-2011, 07:35 PM
Bonki' Ehrite!
ANC297's Avatar
Its a one way check valve...
sockr1
10-01-2015 01:31 AM
PortlandRL
09-14-2015 12:01 PM
DDTsx06
09-08-2015 06:56 PM
Tsov Tom
09-06-2015 07:56 AM
NSolace
09-03-2015 08:02 PM
Quick Reply: PCV valve good or bad
