Passenger front door.
Registered Member
I've been having this issue with my passenger front door for a while but because it closes properly with force not slamming I just rolled with it. But now it's starting to annoying me.
When I open it with the door handle I have to pull on it from outside / push it while inside and it feels very stiff like seized hinges but there's grease on them... When I close it normal it catches but don't close... I have to push on it or close it firmly
Is this an adjustment issue or do I need new hinges?
Registered Member
Check your latch adjustment. Also, does the door drop a bit when opening? Does it rise a bit when closing? Perhaps the door pins in the hinges are getting loose.
Registered Member
Passenger Door.
I don't know how to do a latch adjust on the doors. I've on'y done it to my civic hood... And no it doesn't rise or drop when opening/cosing . it's just stiff and heavy feeling. When you close it you don't get that silent thump .. Its like metallic like shutting it on your seatbelt buckle..
As for grease the hinges I use some white lithium grease but not sure if it's enough and the can is done...
That middle arm piece that stretches between the door and the body should that be greased and with what?
Thanks.
Thanks.
DeathMetal
Third Generation TL (2004-2008)
01-17-2019 01:53 AM
drtoth
Second Generation TL (1999-2003)
07-25-2017 04:15 PM
NC916
10-18-2012 06:27 PM
mokTL
07-28-2009 10:01 PM
Rice1304
02-25-2001 10:27 PM
