P1709 Error Code
P1709 Error Code
The other day my check engine light turned on and so i had my cousin connect his palm pilot to my computer to check it out. I received the error code P1709 and i looked it up and it was Automatic Transaxle (transmission) System Malfunction. I cleared the code and i havent had a problem with it anymore but im curious to know if anyone knows why this might have happened. thanx
6th Gear
I'M A SERVICE ADVISOR AT AN ACURA DEALER IN NY AND HAVE A WHITE 03 TYPE S. WE USE A PGM TESTER TO DIAGNOSE CODES FOR VARIOUS COMPUTER PROBLEMS. I'M WITH YARON ON THIS ONE. HOW ON EARTH DID U GET A CODE WITH A PALM PILOT & WHERE DID YOU FIND THE PROPER CONNECTION. SEEMS VERY INTERESTING TO ME.
Basically my cousin uses a palm pilot along with a special connection that they sell for it and it fits right into the computer slot on my car. It should fit on all TL's 99+ because so far it worked on my car and also my brother that has a 2002 TL-S. My cousin uses the palm pilot on his eclipse to tune his car. Every time he races or modifies something on his car he hooks up the palm pilot and reads all the information and then he tunes it. That thing canm do all kinds of things. For example..he can graph like a few different races and look at the differences in all the races by that he tunes his car and stuff like that. If any of the service lights come on it either gives you a description of the problem or a general code and then you can also reset it if u want. Im gonna find out the website he got it from if you guys like and i will post it.
I've got one of these scanners myself. I bought the software and cable to hook up my Sony Clie to read OBDII error codes for any car from 1996 and newer. I can read check engine light codes and also reset the light as well. A must-have if you do a lot of work on your own car.
Acura TLS are SLOW
which company did you fellas order from? the obd2.com or obd-2.com
which one is better . they seem to be the same but the price difference of the 2 company are dramatic. one is around $150 and the other is $300
6th Gear
hey acura frank i think thats really kool. didn't think it ws at all possible. if u can post what kind of program & connection is used and where we can find them - u da man !
jptls21, being a writer fro an acura dealer i see about a tranny or two a week. been worse, but been better. thats only my one dealer. rumor has it it was corrected for 03 models. but then again i've seen 03's come back witrh bad trannies. not too often though. i got about 7500 miles no problems yet. keepin my fingers crossed.
DJSALG, the one i used on my car was one that my cousin bought at www.pocketlogger.com. It works pretty good. Take a look at the site. They are selling the Palm Pilot, the software(which is OBD-II), and the cable for like $175.
Jamus22
06-11-2023 10:08 AM
2002, 2003, acura, cel, code, error, malfunction, p1709, p1709automatic, reset, system, tl, transmission, trouble, type
